capacitive sensor
Wearable electronics: boards, conductive materials, and projects from Adafruit!
salahjardali
capacitive sensor
Post by salahjardali »
Hi
Iam using the capacitive sensor with Neopixel. When i upload the code, the program give me an error regarding the RGBpixel. Here is the code
#include <CapacitiveSensor.h>
#include "Adafruit_NeoPixel.h"
 * CapitiveSense Library Demo Sketch
 * Paul Badger 2008
 * Uses a high value resistor e.g. 10M between send pin and receive pin
 * Resistor effects sensitivity, experiment with values, 50K - 50M. Larger resistor values yield larger sensor values.
 * Receive pin is the sensor pin - try different amounts of foil/metal on this pin
 * Modified by Becky Stern 2013 to change the color of one RGB Neo Pixel based on touch input
CapacitiveSensor   cs_9_10 = CapacitiveSensor(9,10);        // 10M resistor between pins 4 & 2, pin 2 is sensor pin, add a wire and or foil if desired
//CapacitiveSensor   cs_9_2 = CapacitiveSensor(9,2);        // 10M resistor between pins 4 & 6, pin 6 is sensor pin, add a wire and or foil
//CapacitiveSensor   cs_4_8 = CapacitiveSensor(4,8);        // 10M resistor between pins 4 & 8, pin 8 is sensor pin, add a wire and or foil
Adafruit_NeoPixel strip = Adafruit_NeoPixel(1);
void setup()
   cs_9_10.set_CS_AutocaL_Millis(0xFFFFFFFF);     // turn off autocalibrate on channel 1 - just as an example
   Serial.begin(9600);
    strip.begin();
    strip.show();
void loop()
    long start = millis();
    long total1 =  cs_9_10.capacitiveSensor(30);
    //long total2 =  cs_9_2.capacitiveSensor(30);
    //long total3 =  cs_4_8.capacitiveSensor(30);
if (total1 > 75){
  digitalWrite(7, HIGH);
  strip.setPixelColor(0, Color(0,255,0));
  strip.show();
} else {
  strip.setPixelColor(0, Color(0,0,0));
  strip.show();
    Serial.print(millis() - start);        // check on performance in milliseconds
    Serial.print("\t");                    // tab character for debug windown spacing
    Serial.println(total1);                  // print sensor output 1
    //Serial.print("\t");
    //Serial.println(total2);                  // print sensor output 2
    //Serial.println(total3);                // print sensor output 3
    delay(10);                             // arbitrary delay to limit data to serial port
// Create a 24 bit color value from R,G,B
RGBPixel Color(byte r, byte g, byte b)
  RGBPixel p;
  p.red = r;
  p.green = g;
  p.blue = b;
  return p;
Last edited by adafruit_support_bill on Fri Mar 23, 2018 6:06 am, edited 1 time in total.
Reason: fixed [code] tags
Re: capacitive sensor
It would help if you posted the error code too.
From the looks of it, you are missing the closeing '}' bracket on your Color function. And I don't see anywhere that you are defining the RGBPixel type.
salahjardali
Hi now there is no error, but the neo pixel is not lighting when i touch the fabric. Only the LED 7 is lighting. and this is my code:
#include "Adafruit_FloraPixel.h"
 * Paul Badger 2008
Adafruit_FloraPixel strip = Adafruit_FloraPixel(1);
void setup()
   Serial.begin(9600);
    strip.begin();
    strip.show();
void loop()
if (total1 > 75){
  strip.show();
} else {
  strip.show();
  RGBPixel p;
  p.red = r;
  p.green = g;
  p.blue = b;
  return p;
Last edited by adafruit_support_bill on Sat Apr 07, 2018 6:42 am, edited 1 time in total.
Please post photos showing your soldering and connections.
Return to “Wearables”
