Need help, Firewalkers 1.0/2.0
by ShaolinSolidus on Fri Jun 15, 2018 2:50 pm
I was wondering if anyone had monster-mashed the firewalker code from the 1.0 and the 2.0. I like the animation of the 1.0 but the addition of the vibration sensor is much more appealing to me. I have a few flora but no gemma boards, and that seems to be a problem when trying to upload the new 2.0 code to a flora, there are a lot of "not declared in this scope" error's. I would prefer to make use of the flora boards if at all possible and not have to go and buy 6 new gemma (making some shoes for myself and my friends) I just find that the analog read of the velostat to be somewhat unreliable and sporadic. I'm not adept with coding at all which is why I'm asking if anyone has done this, thanks :)
Last edited by ShaolinSolidus on Wed Jul 11, 2018 3:04 pm, edited 1 time in total.
ShaolinSolidus
Re: Firewalkers 1.0/2.0
by ledbear on Mon Jun 18, 2018 2:32 pm
Hey, I have been messing around with the firewalkers and modifying to I can run it on my Gemma M0. The CircuitPython code that in the demo for anything thats not Gemma will just not run. Way to slow. But, since I've almost adjusted the code for what you asked for (I used a microphone for input in one project and a vibration module in the other), I figured I could help you out. This code works with my sensitive vibration sensor, but its in a backpack rather then on shoes, so I think it will work for you too. You should be able to tweak the STEP_TRIGGER, STEP_HYSTERESIS and SLOWDOWN_RATE. Since this all is kind of backwards, (when you press down the foot the resistance goes down) I have just taken some short cuts. When an interrupt sense a vibration the stepFiltered variable is lowered under the STEP_TRIGGER value, and then for each loop that value is increased by the SLOWDOWN_RATE until we are over the STEP_HYSTERESIS by 50. If you want it to take longer time lower the SLOWDOWN_RATE and increase the value that set in the onShake method (or it will take a long time to even start a animation). Default values looks good on my Gemma M0 though. Good luck!
// 'Firewalker' LED sneakers sketch for Adafruit NeoPixels by Phillip Burgess
// Modified by Ledbear 29180618
#include <Arduino.h>
const uint8_t gammaConst[] PROGMEM = { // Gamma correction table for LED brightness
    0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,
    0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  1,  1,  1,  1,
    1,  1,  1,  1,  1,  1,  1,  1,  1,  2,  2,  2,  2,  2,  2,  2,
    2,  3,  3,  3,  3,  3,  3,  3,  4,  4,  4,  4,  4,  5,  5,  5,
    5,  6,  6,  6,  6,  7,  7,  7,  7,  8,  8,  8,  9,  9,  9, 10,
   10, 10, 11, 11, 11, 12, 12, 13, 13, 13, 14, 14, 15, 15, 16, 16,
   17, 17, 18, 18, 19, 19, 20, 20, 21, 21, 22, 22, 23, 24, 24, 25,
   25, 26, 27, 27, 28, 29, 29, 30, 31, 32, 32, 33, 34, 35, 35, 36,
   37, 38, 39, 39, 40, 41, 42, 43, 44, 45, 46, 47, 48, 49, 50, 50,
   51, 52, 54, 55, 56, 57, 58, 59, 60, 61, 62, 63, 64, 66, 67, 68,
   69, 70, 72, 73, 74, 75, 77, 78, 79, 81, 82, 83, 85, 86, 87, 89,
   90, 92, 93, 95, 96, 98, 99,101,102,104,105,107,109,110,112,114,
  115,117,119,120,122,124,126,127,129,131,133,135,137,138,140,142,
  144,146,148,150,152,154,156,158,160,162,164,167,169,171,173,175,
  177,180,182,184,186,189,191,193,196,198,200,203,205,208,210,213,
  215,218,220,223,225,228,231,233,236,239,241,244,247,249,252,255 };
// LEDs go around the full perimeter of the shoe sole, but the step animation
// is mirrored on both the inside and outside faces, while the strip doesn't
// necessarily start and end at the heel or toe.  These constants help configure
// the strip and shoe sizes, and the positions of the front- and rear-most LEDs.
// Becky's shoes: 39 LEDs total, 20 LEDs long, LED #5 at back.
// Phil's shoes: 43 LEDs total, 22 LEDs long, LED #6 at back.
#define N_LEDS        60 // TOTAL number of LEDs in strip
#define SHOE_LEN_LEDS 30 // Number of LEDs down ONE SIDE of shoe
#define SHOE_LED_BACK  30 // Index of REAR-MOST LED on shoe
#define SLOWDOWN_RATE  20 //how fast after a vibration should pressure reading go down
#define LED_PIN        1 // NeoPixel strip is connected here
#define MAXSTEPS       3 // Process (up to) this many concurrent steps
#define MOTION_PIN     0 // Vibration switch from here to GND
Adafruit_NeoPixel strip = Adafruit_NeoPixel(N_LEDS, LED_PIN, NEO_GRB + NEO_KHZ800);
// The readings from the sensors are usually around 250-350 when not being pressed,
// then dip below 100 when the heel is standing on it (for Phil's shoes; Becky's
// don't dip quite as low because she's smaller).
#define STEP_TRIGGER    150  // Reading must be below this to trigger step
#define STEP_HYSTERESIS 200  // After trigger, must return to this level
int
  stepMag[MAXSTEPS],  // Magnitude of steps
  stepX[MAXSTEPS],    // Position of 'step wave' along strip
  mag[SHOE_LEN_LEDS], // Brightness buffer (one side of shoe)
  stepFiltered,       // Current filtered pressure reading
  stepCount,          // Number of 'frames' current step has lasted
  stepMin;            // Minimum reading during current step
uint8_t
  stepNum = 0,        // Current step number in stepMag/stepX tables
  dup[SHOE_LEN_LEDS]; // Inside/outside copy indexes
boolean
  stepping  = true;  // If set, step was triggered, waiting to release
int8_t loopvariable = 0;
  pinMode(MOTION_PIN, INPUT_PULLUP);
  // As previously mentioned, the step animation is mirrored on the inside and
  // outside faces of the shoe.  To avoid a bunch of math and offsets later, the
  // 'dup' array indicates where each pixel on the outside face of the shoe should
  // be copied on the inside.  (255 = don't copy, as on front- or rear-most LEDs).
  // Later, the colors for the outside face of the shoe are calculated and then get
  // copied to the appropriate positions on the inside face.
  memset(dup, 255, sizeof(dup));
  int8_t a, b;
  for(a=1              , b=SHOE_LED_BACK-1            ; b>=0    ;) dup[a++] = b--;
  for(a=SHOE_LEN_LEDS-2, b=SHOE_LED_BACK+SHOE_LEN_LEDS; b<N_LEDS;) dup[a--] = b++;
  // Configure motion pin for change detect & interrupt
   attachInterrupt(                  // register Interrupt Service Routine (ISR):
    digitalPinToInterrupt(MOTION_PIN),  //   pin to watch for interrupt
    onShake,                     //   void function to call on interrupt
    FALLING                         //   trigger interrupt on HIGH → LOW change
  // Clear step magnitude and position buffers
  memset(stepMag, 0, sizeof(stepMag));
  memset(stepX  , 0, sizeof(stepX));
  strip.begin();
void onShake(){
  stepFiltered = 9;
  uint8_t i, j;
  if(stepFiltered < STEP_HYSTERESIS + 50){
    stepFiltered = stepFiltered + SLOWDOWN_RATE;
  //Serial.println("stepFiltered=" + String(stepFiltered));
  // The strip doesn't simply display the current pressure reading.  Instead,
  // there's a bit of an animated flourish from heel to toe.  This takes time,
  // and during quick foot-tapping there could be multiple step animations
  // 'in flight,' so a short list is kept.
  if(stepping) { // If a step was previously triggered...
    if(stepFiltered >= STEP_HYSTERESIS) { // Has step let up?
      stepping = false;                   // Yep! Stop monitoring.
      // Add new step to the step list (may be multiple in flight)
      stepMag[stepNum] = (STEP_HYSTERESIS - stepMin) * 6; // Step intensity
      stepX[stepNum]   = -80; // Position starts behind heel, moves forward
      if(++stepNum >= MAXSTEPS) stepNum = 0; // If many, overwrite oldest
    } else if(stepFiltered < stepMin) stepMin = stepFiltered; // Track min val
  } else if(stepFiltered < STEP_TRIGGER) { // No step yet; watch for trigger
    stepping = true;         // Got one!
    stepMin  = stepFiltered; // Note initial value
  // Render a 'brightness map' for all steps in flight.  It's like
  // a grayscale image; there's no color yet, just intensities.
  int mx1, px1, px2, m;
  memset(mag, 0, sizeof(mag));    // Clear magnitude buffer
  for(i=0; i<MAXSTEPS; i++) {     // For each step...
    if(stepMag[i] <= 0) continue; // Skip if inactive
    for(j=0; j<SHOE_LEN_LEDS; j++) { // For each LED...
      // Each step has sort of a 'wave' that's part of the animation,
      // moving from heel to toe.  The wave position has sub-pixel
      // resolution (4X), and is up to 80 units (20 pixels) long.
      mx1 = (j << 2) - stepX[i]; // Position of LED along wave
      if((mx1 <= 0) || (mx1 >= 80)) continue; // Out of range
      if(mx1 > 64) { // Rising edge of wave; ramp up fast (4 px)
        m = ((long)stepMag[i] * (long)(80 - mx1)) >> 4;
      } else { // Falling edge of wave; fade slow (16 px)
        m = ((long)stepMag[i] * (long)mx1) >> 6;
      mag[j] += m; // Add magnitude to buffered sum
    stepX[i]++; // Update position of step wave
    if(stepX[i] >= (80 + (SHOE_LEN_LEDS << 2)))
      stepMag[i] = 0; // Off end; disable step wave
    else
      stepMag[i] = ((long)stepMag[i] * 127L) >> 7; // Fade
  // For a little visual interest, some 'sparkle' is added.
  // The cumulative step magnitude is added to one pixel at random.
  long sum = 0;
  for(i=0; i<MAXSTEPS; i++) sum += stepMag[i];
  if(sum > 0) {
    i = random(SHOE_LEN_LEDS);
    mag[i] += sum / 4;
  // Now the grayscale magnitude buffer is remapped to color for the LEDs.
  // The code below uses a blackbody palette, which fades from white to yellow
  // to red to black.  The goal here was specifically a "walking on fire"
  // aesthetic, so the usual ostentatious rainbow of hues seen in most LED
  // projects is purposefully skipped in favor of a more plain effect.
  uint8_t r, g, b;
  int     level;
  for(i=0; i<SHOE_LEN_LEDS; i++) { // For each LED on one side...
    level = mag[i];                // Pixel magnitude (brightness)
    if(level < 255) {              // 0-254 = black to red-1
      r = pgm_read_byte(&gammaConst[level]);
      g = b = 0;
    } else if(level < 510) {       // 255-509 = red to yellow-1
      r = 255;
      g = pgm_read_byte(&gammaConst[level - 255]);
      b = 0;
    } else if(level < 765) {       // 510-764 = yellow to white-1
      r = g = 255;
      b = pgm_read_byte(&gammaConst[level - 510]);
    } else {                       // 765+ = white
      r = g = b = 255;
    // Set R/G/B color along outside of shoe
    strip.setPixelColor(i+SHOE_LED_BACK, r, g, b);
    // Pixels along inside are funny...
    j = dup[i];
    if(j < 255) strip.setPixelColor(j, r, g, b);
  strip.show();
  delayMicroseconds(1500);
ledbear
by ShaolinSolidus on Mon Jun 25, 2018 2:19 pm
Thanks ledbear, I still seem to be having troubles triggering the vibration sensor. I tried changing the 3 variables like you had suggested with no luck. If I make the value of STEP_HYSTERESIS smaller than STEP_TRIGGER it doesn't seem to trigger, whereas if I leave the values you have in the code you posted, it trigger upon boot and then not afterward. I can see that SLOWDOWN_RATE delays or speeds up the trigger upon boot, but I can still not manage to make it trigger with the vibration sensor. I did end up getting 1 Gemma to test, and like I had mentioned previously I prefer the old animation, but I do love the vibration sensor instead of the vleostat. If I'm missing something obvious I would love for you to fill me in, Thanks.
P.S. I would love to see the backpack you made, I made a set for myself and my brother that we wear to music festivals. they are 3d printed shells with individual segments to look somewhat like a turtle shell, and in the center I put a hub 7 display with a smartmatrix controller and microphone for sound sensitivity. (also made a set of daft punk helmets.
ShaolinSolidus
by ShaolinSolidus on Fri Jun 29, 2018 4:40 pm
Is there anyone that has a suggestion on how to get this code working with my flora? or even a gemma? I would just prefer the old animation with the vibration sensor if anyone can help make sense of ledbear's code and what they meant?
ShaolinSolidus
by ShaolinSolidus on Wed Jul 11, 2018 3:02 pm
I have made strips of individual led's because I have tried these shoes before (3 years in a row 3 times) and the strips always fail. I liked the solution the new firewalkers had and I thought I would do the whole shoe that way, and will either encase in vulcanizing clear rubber or just silicone.
I ended up getting gemma controllers and I love the vibration sensor, but I still can't figure out how to use the old animation code that ledbear posted. I like the new animation, but the old one is still my preference. If anyone has any suggestions of what I might be able to try I would really appreciate the help
ShaolinSolidus
