Create Beanie Hat with LED (w Switch)
Wearable electronics: boards, conductive materials, and projects from Adafruit!
nieriel
Post by nieriel »
I run programs for adults in a public library makerspace, but am new to tech-based projects. So, I'm trying to start small!
I want to do this project: https://youtu.be/lpf-znZNfC8 ("How to add an LED to a beanie hat").
Would the 12mm Coin Cell Breakout w/ On-Off Switch (#1867) https://www.adafruit.com/product/1867 and Adafruit LED Sequins (#1758) https://www.adafruit.com/product/1758 work?
As I have to order enough for 12 students, I don't want to mess up.
If you have different suggestions, any advice is appreciated. :)
Thank you so much!
Re: Create Beanie Hat with LED (w Switch)
Yes. The sequins should work well with the coin-cell holder.
nieriel
Post by nieriel »
adafruit_support_bill, thank you SO much for your help! I (and my students) really appreciate it. :)
adafruit_support_bill wrote:Yes. The sequins should work well with the coin-cell holder.
nieriel
Post by nieriel »
Hello, so I purchased a 12mm coin cell breakout board, LED light, and conductive thread.
I've tried sewing the circuit on felt, and it did not work. I then tried to sew it without the felt, and it still does not work.
I've attached a photo--it's not great quality, so I had to do it again not on the felt (and it didn't work then either). Please help!
Thanks. :)
You have made your connections to the mounting holes. Those have no connection to the battery.
Connect the '-' side of the sequin to one of the GND holes.
Connect the '+' side of the sequin to the SW hole.
Use the switch to turn it on and off.
nieriel
Post by nieriel »
It worked!!! THANK YOU SO MUCH!!!
Good to hear. Thanks for the follow-up.
Return to “Wearables”
