I am basically making a fancy flash light with neopixels. It'll do a startup pretty color sequence, then changes all the neopixels to white. I am using a 5vdc 2.1 Amp power source, a Flora, a 24 neopixel ring in sequence with a 12 neopixel ring. There is a switch between the power supply and the board. This is for work, I made one like a year ago and it works great, and now they want 4 more, but my notes on the project apparently aren't that great.
I am having an issue where the neopixels dim after a few moments, seemingly while the code is in void loop, however the single line of code run in the loop is the same that ends the void startup and this doesn't make sense to me. This happens in all 4 'flashlights.' See code below. It dims If it's connected to the computer or to the power supply, although it takes longer to dim if it's connected to the computer. When it is connected to the computer and dims I am no longer able to see it in the connected ports, like it's lost the data connection.
Any help on this issue would be much appreciated.
#include "Adafruit_FloraPixel.h"
//Flash light locking switch input:
#define PIN 8
Adafruit_NeoPixel strip = Adafruit_NeoPixel(40);//, PIN, NEO_GRB + NEO_KHZ800);
strip.begin();
strip.show(); // Initialize all pixels to 'off'
rainbowCycle(2);
//RED
//colorWipe(strip.Color(255, 0, 75), 10); // Red
//colorWipe(strip.Color(255, 0, 25), 12); // Red
//colorWipe(strip.Color(255, 0, 0), 16); // Red
//BLUE
colorWipe(strip.Color(0, 50, 255), 20); // Blueish
colorWipe(strip.Color(0, 100, 150), 20); //Tealish
colorWipe(strip.Color(0, 180, 180), 25); // Tealish 2
//GREEN
//colorWipe(strip.Color(0, 255, 75), 50); // Green
//colorWipe(strip.Color(0, 255, 35), 50); // Green
//colorWipe(strip.Color(0, 255, 0), 50); // Green
//PURPLE
//colorWipe(strip.Color(255, 75, 255), 50); // Purple
//colorWipe(strip.Color(255, 35, 255), 50); // Purple
//colorWipe(strip.Color(255, 0, 255), 50); // Purple
delay(500);
colorWipe(strip.Color(180, 180, 180), 50); // White
colorWipe(strip.Color(180, 180, 180), 250); // White
// Fill the dots one after the other with a color
void colorWipe(uint32_t c, uint8_t wait) {
for(uint16_t i=0; i<strip.numPixels(); i++) {
strip.setPixelColor(i, c);
strip.show();
delay(wait);
// Slightly different, this makes the rainbow equally distributed throughout
void rainbowCycle(uint8_t wait) {
uint16_t i, j;
for(j=0; j<256*3; j++) { // 3 cycles of all colors on wheel
for(i=0; i< strip.numPixels(); i++) {
strip.setPixelColor(i, Wheel(((i * 256 / strip.numPixels()) + j) & 255));
strip.show();
delay(wait);
// Input a value 0 to 255 to get a color value.
// The colours are a transition r - g - b - back to r.
uint32_t Wheel(byte WheelPos) {
WheelPos = 255 - WheelPos;
if(WheelPos < 85) {
return strip.Color(255 - WheelPos * 3, 0, WheelPos * 3);
} else if(WheelPos < 170) {
WheelPos -= 85;
return strip.Color(0, WheelPos * 3, 255 - WheelPos * 3);
} else {
WheelPos -= 170;
return strip.Color(WheelPos * 3, 255 - WheelPos * 3, 0);
