Gemmo MO no connection
- Bragxiii
When I plug my Gemmo MO in the computer it give me no lights, the only thing I see is a quick blue blip them nothing. I could see it being a cable but I purchased 2 at the same time and the other connected and I set up as CircuitPython with no problems? I even tried using the JST connect with AAA that runs the other Gemmo MO just fine and no lights appear.
- 20181030_211619.jpg (22.82 KiB) Viewed 196 times
- danhalbert
Re: Gemmo MO no connection
If you double-click the reset button fast does anything happen? I assume you've flipped the on-off switch off and on?
- Bragxiii
Correct, single tap, double tap, triple tap and holding don't seem to have any affect on or off. If the switch is to the off position then switched to on it does blip blue for a split second but that is it.
- danhalbert
OK, it looks broken. Happy to replace. Send an email to [email protected] with a pointer to this thread, saying that a replacement has been authorized. Include your order number.
