Hello! I have hooked everything up according to the project (https://learn.adafruit.com/flora-gps-jacket/), and my serial monitor is reflecting GPS coordinates correctly and my neopixels are lighting up BUT the problem is they are always lighting up no matter how much I change the GPS locations! I am using pretty much the exact code from the project page minus a few differences -- see following:
Here are my coordinates: (37.875115,-122.258222)
I change the following to my coordinates:
#define GEO_LAT
#define GEO_LON
and I make sure my
#define DESTINATION_DISTANCE
is only 2 meters
SO when I change the GEO_LAT and GEO_LON to crazy numbers far far away, it uploads successfully but the LEDS never go out. They keep staying on. I also only have 2 LEDS but did change this line:
Adafruit_FloraPixel strip = Adafruit_FloraPixel(2);
to 2 since I only have 2!
SO my question is why don't the LEDS go out? I want them to turn on when i'm close to the GPS coordinates like shown in the project video
ALSO there are other parts of the code where it can show you where to go....what do those require,, just LEDS? Or can you use a screen?
Flora GPS Jacket project issue
Re: Flora GPS Jacket project issue
Uncomment line 149 to see how far the code thinks you are from the destination:
headingDistance((double)calc_dist(fLat, fLon, targetLat, targetLon));
//Serial.print("Distance Remaining:"); Serial.println((double)calc_dist(fLat, fLon, targetLat, targetLon));
- Mathpun
Thanks for your reply! I did that and it said:
Distance Remaining:12781405.00
12781405.00
12781405.00
So what does that mean?
12781405.00
12781405.00
That's definitely larger than the distant constant should be.
Head down to the function headingDistance() around line 260, and uncomment the diagnostic Serial.print() statements there. That will tell you whether the logic is doing what it's supposed to.
