Accelerometer stopped functioning
by ktaylo51 on Tue Feb 11, 2020 3:09 pm
My daughter built the sparkle skirt for a school project using the FLORA Accelerometer/Compass Sensor - LSM303. When she completed the project everything functioned as expected. The morning of the tech fair she wanted to test it and it was not functional. Through a series of tests we were able to determine that the accelerator was not longer functioning.
She has resewn all of the connections with the 3g thread and it didn't help. Fortunately I was able to comment out the accelerometer from the code, but she needs it for her next presentation.
it seems to have died after the first use, has anyone else had this issue? All of the ways to test I have found haven't been able to convince me it's anything with the code, board, or pixels as they are all working great when it's commented out of the code.
Kyle
ktaylo51
Re: Accelerometer stopped functioning
by mikeysklar on Tue Feb 11, 2020 4:41 pm
Hi Kyle,
Can we review how the accelerometer is wired/sewn into the garment? Do you have photos?
mikeysklar
by ktaylo51 on Sat Feb 15, 2020 12:01 pm
Absolutely, I'll take photos today and upload them tonight.
Kyle
ktaylo51
by ktaylo51 on Wed Feb 19, 2020 2:49 pm
Images attached.
ktaylo51
by mikeysklar on Tue Feb 25, 2020 5:37 pm
Hello ktaylo51,
Thank you for the photos.
When you use an accelerometer to measure the resistance between the Lora and the Accelerometer what do you see on the SDA pads and SDL pads?
mikeysklar
by ktaylo51 on Wed Feb 26, 2020 12:00 pm
mikeysklar wrote:Hello ktaylo51,
Hi Mikey,
I am not fully sure what you mean - but when I run the adafruit provided accellerometer test it says in the window that it cannot find accellerometer. I'm concerned that it is dead as the whole project was functioning perfectly and then the next day it was not working.
How do I test the SDA and SDL pads?
ktaylo51
by mikeysklar on Wed Feb 26, 2020 1:57 pm
I'm sorry. I mean to say when you use a multimeter to measure the resistance between the Lora and accelerometer SDA and SDL pads what is the reading?
mikeysklar
by ktaylo51 on Wed Feb 26, 2020 3:06 pm
I'll try this when I get home and report back later this afternoon.
I haven't tried with a multimeter just yet. Red on Battery and neg on each of those?
ktaylo51
by mikeysklar on Wed Feb 26, 2020 4:00 pm
You want to measure conductivity so set the meter to the "ohm" symbol and measure SDA to SDA on the Lora to Accelerometer then SDL to SDL.
mikeysklar
by ktaylo51 on Wed Feb 26, 2020 4:47 pm
Perfect, thank you.
ktaylo51
by jcnayes on Tue Jun 16, 2020 5:34 am
My Flora + 303DLHC is also no longer working. My project was on the shelf for awhile, but now I'm not able to get very far, even using the test code. I remember putting the project on the shelf after getting values but not getting far interpreting them for the effects I wanted. My motivation is back a bit now, and I need help getting the sensor to start working!
I'm running the example code for the 'Adafrui LSM303 Accel - accelsensor' code. The serial monitor shows the 'Accelerometer Test' line, but (even with the sensor sitting in the window for 10 minutes), nothing else happens. One time I got the 'no LSM 303 detected' note...
Thoughts?
Debug info:
#include <Adafruit_LSM303_Accel.h>
#include <Adafruit_Sensor.h>
#include <Wire.h>
/* Assign a unique ID to this sensor at the same time */
Adafruit_LSM303_Accel_Unified accel = Adafruit_LSM303_Accel_Unified(54321);
void displaySensorDetails(void) {
  sensor_t sensor;
// ..... (etc)...
When powered off, I get about 3 ohm on the SCL pins and about 3 ohm on the SDA pins:
Software versions:
Arduino: 1.8.11 on Windows 10 (not working on my Mac either...)
Adafruit AVR Boards 1.4.13
Adafruit LSM303 Accel 1.1.4
Adafruit Unified Sensor 1.1.3
jcnayes
by jcnayes on Tue Jun 16, 2020 9:39 am
jcnayes wrote:My Flora + 303DLHC is also no longer working. My project was on the shelf for awhile, but now I'm not able to get very far, even using the test code. I remember putting the project on the shelf after getting values but not getting far interpreting them for the effects I wanted. My motivation is back a bit now, and I need help getting the sensor to start working!
Thoughts?
I tested the same LSM303 sensor with an Arduino Uno, same test code, using alligator clips to the snaps soldered to my LSM303, and I did get the expected results! The serial monitor lit up right away with sensor info and a continuously updating set of readings. I would assume that this means the issue is on the Flora.
jcnayes
by adafruit_support_bill on Tue Jun 16, 2020 9:49 am
Can you post some close-up photos so we can better see your connections? Are you using conductive thread, or wire with solder?
cron
