Black Lives Matter - Action and Equality. ... Adafruit is part of the Stop Hate for Profit campaign. Adafruit is open and shipping.
Flora V3 neopixel only blue
by kelad on Sun Mar 01, 2020 2:25 am
Hi Guys
I'm playing with the Flora V3 and loading in the sample code given to 'blink the on-board neopixel'. I load the code ok, however the neopixel only ever lights up blue.
It stays blue solid for seconds, then flashes, turns off for a few seconds and then repeats.
I think the colorWipe and rainbowCycle code is running, but only blue is shown. Really weird. I even tried only this command
strip.setPixelColor(0, 255, 0, 0);
for red, but neopixel remains off. If I put
strip.setPixelColor(0, 0, 0, 255); then it lights blue.
Can anyone help? Is this board a dud?
Tom
kelad
Re: Flora V3 neopixel only blue
by kelad on Thu Mar 05, 2020 5:06 am
Weird. Today I tried again and strip.setPixelColor(0, 255, 0, 0); now gives me red, however green does not work i.e strip.setPixelColor(0, 0, 255, 0)
Red and Blue work but no green....any hints? I have tried everything.
Thanks alot.
kelad
by kelad on Sat Mar 07, 2020 5:12 am
Ok, so I assume this is faulty. How can I return and get a replacement ? Thanks
kelad
by adafruit_support_carter on Thu Mar 12, 2020 4:52 pm
Sounds like it might be a flakey NeoPixel. Let's double check with one more sketch. Try running this:
#define PIN 8
Adafruit_NeoPixel strip = Adafruit_NeoPixel(1, PIN, NEO_GRB + NEO_KHZ800);
  strip.begin();
  strip.setPixelColor(0, 0xFFFFFF);
  strip.show();
Which should turn on all 3 color channels. Is the result for you white or magenta?
