Help with propmaker project
by TheGnomeQueen on Fri May 01, 2020 9:16 pm
Hi everyone!
I recently purchased a propmaker and feather m4 express to follow this tutorial:
https://learn.adafruit.com/burning-fire-wizard-staff/overview
I assembled all parts and setup my board according to the instructions. I also changed my .wav files and rgb colors for the leds. Once I uploaded the code everything worked fine for a few runs. Now the code will no longer work. When I power it on, the led on the feather turns green, then yellow and then quickly flashes yellow once and cyan six times. From what I read in the troubleshooting guide, I believe this means there is an error on line 16 of the code, but the only thing on that line is import audiocore
I tried using the original code again, thinking maybe I had made a mistake in my editing, but still the error flashes.
This is the original code from the tutorial.
Prop-Maker based Burning Wizard Staff
Adafruit invests time and resources providing this open source code.
Please support Adafruit and open source hardware by purchasing
products from Adafruit!
Written by Kattni Rembor, Erin St Blaine & Limor Fried for Adafruit Industries
Copyright (c) 2020 Adafruit Industries
Licensed under the MIT license.
All text above must be included in any redistribution.
import time
import random
import digitalio
import audioio
import audiocore
import board
import neopixel
import adafruit_lis3dh
# CHANGE TO MATCH YOUR RING AND STRIP SETUP
NUM_RING = 12   #12 pixel ring
NUM_STRIP = 44  # 44 pixels in my NeoPixel strip
NUM_PIXELS = NUM_STRIP + NUM_RING  #total number of pixels
NEOPIXEL_PIN = board.D5  # PropMaker Wing uses D5 for NeoPixel plug
POWER_PIN = board.D10
# CUSTOMISE COLORS HERE:
COLOR = (200, 30, 0)      # Default idle is orange
ALT_COLOR = (0, 200, 200)  # hit color is teal
SWING_COLOR = (200, 200, 200) #swing animation color is white
TOP_COLOR = (100, 100, 0)  #top color is yellow-green
YELL_COLOR = (200, 0, 200)  #yell color is purple
# CUSTOMISE IDLE PULSE SPEED HERE: 0 is fast, above 0 slows down
IDLE_PULSE_SPEED = 0  # Default is 0 seconds
SWING_BLAST_SPEED = 0.007
# CUSTOMISE BRIGHTNESS HERE: must be a number between 0 and 1
IDLE_PULSE_BRIGHTNESS_MIN = 0.2  # Default minimum idle pulse brightness
IDLE_PULSE_BRIGHTNESS_MAX = 1  # Default maximum idle pulse brightness
# CUSTOMISE SENSITIVITY HERE: smaller numbers = more sensitive to motion
HIT_THRESHOLD = 1150
SWING_THRESHOLD = 800
YELL_THRESHOLD = 700
# Set to the length in seconds of the "on.wav" and "yell1.wav" files
POWER_ON_SOUND_DURATION = 3.0
YELL_SOUND_DURATION = 1.0
enable = digitalio.DigitalInOut(POWER_PIN)
enable.direction = digitalio.Direction.OUTPUT
enable.value = False
# Set up NeoPixels
strip = neopixel.NeoPixel(NEOPIXEL_PIN, NUM_PIXELS, brightness=1, auto_write=False)
strip.fill(0)  # NeoPixels off ASAP on startup
strip.show()
audio = audioio.AudioOut(board.A0)  # Speaker
wave_file = None
# Set up accelerometer on I2C bus, 4G range:
i2c = board.I2C()
accel = adafruit_lis3dh.LIS3DH_I2C(i2c)
accel.range = adafruit_lis3dh.RANGE_4_G
COLOR_IDLE = COLOR # 'idle' color is the default for the staff handle
COLOR_HIT = ALT_COLOR  # "hit" color is ALT_COLOR set above
COLOR_SWING = SWING_COLOR  # "swing" color is SWING_COLOR set above
COLOR_TOP = TOP_COLOR  #"top" color is idle color for the ring
def play_wav(name, loop=False):
    Play a WAV file in the 'sounds' directory.
    :param name: partial file name string, complete name will be built around
                 this, e.g. passing 'foo' will play file 'sounds/foo.wav'.
    :param loop: if True, sound will repeat indefinitely (until interrupted
                 by another sound).
    global wave_file  # pylint: disable=global-statement
    print("playing", name)
    if wave_file:
        wave_file.close()
    try:
        wave_file = open('sounds/' + name + '.wav', 'rb')
        wave = audiocore.WaveFile(wave_file)
        audio.play(wave, loop=loop)
    except OSError:
        pass # we'll just skip playing then
def power(sound, duration, reverse):
    Animate NeoPixels with accompanying sound effect for power on.
    @param sound: sound name (similar format to play_wav() above)
    @param duration: estimated duration of sound, in seconds (>0.0)
    @param reverse: Reverses animation. If True, begins animation at end of strip.
    if reverse:
        prev = NUM_PIXELS
    else:
        prev = 0
    start_time = time.monotonic()  # Save audio start time
    play_wav(sound)
    while True:
        elapsed = time.monotonic() - start_time  # Time spent playing sound
        if elapsed > duration:                   # Past sound duration?
            break                                # Stop animating
        total_animation_time = elapsed / duration            # Animation time, 0.0 to 1.0
        if reverse:
            total_animation_time = 1.0 - total_animation_time            # 1.0 to 0.0 if reverse
        threshold = int(NUM_PIXELS * total_animation_time + 0.5)
        num = threshold - prev # Number of pixels to light on this pass
        if num != 0:
            if reverse:
                strip[threshold:prev] = [ALT_COLOR] * -num
            else:
                strip[prev:threshold] = [ALT_COLOR] * num
            strip.show()
            prev = threshold
def mix(color_1, color_2, weight_2):
    Blend between two colors with a given ratio.
    :param color_1:  first color, as an (r,g,b) tuple
    :param color_2:  second color, as an (r,g,b) tuple
    :param weight_2: Blend weight (ratio) of second color, 0.0 to 1.0
    :return (r,g,b) tuple, blended color
    if weight_2 < 0.0:
        weight_2 = 0.0
    elif weight_2 > 1.0:
        weight_2 = 1.0
    weight_1 = 1.0 - weight_2
    return (int(color_1[0] * weight_1 + color_2[0] * weight_2),
            int(color_1[1] * weight_1 + color_2[1] * weight_2),
            int(color_1[2] * weight_1 + color_2[2] * weight_2))
# List of swing wav files without the .wav in the name for use with play_wav()
swing_sounds = [
    'swing1',
    'swing2',
    'swing3',
# List of hit wav files without the .wav in the name for use with play_wav()
hit_sounds = [
    'hit1',
    'hit2',
    'hit3',
    'hit4',
# List of yell wav files without the .wav in the name for use with play_wav()
yell_sounds = [
    'yell1',
mode = 0  # Initial mode = OFF
# Setup idle pulse
idle_brightness = IDLE_PULSE_BRIGHTNESS_MIN  # current brightness of idle pulse
idle_increment = 0.01  # Initial idle pulse direction
# Main loop
while True:
    if mode == 0:  # If currently off...
        enable.value = True
        power('on', POWER_ON_SOUND_DURATION, True)  # Power up!
        play_wav('idle', loop=True)  # Play idle sound now
        mode = 1  # Idle mode
        time.sleep(1.0) #pause before moving on
        # Setup for idle pulse
        # lights the ring in COLOR_TOP color:
        strip[0:NUM_RING] = [([int(c*idle_brightness) for c in COLOR_TOP])] * NUM_RING
        # lights the strip in COLOR_IDLE color:
        strip[NUM_RING:NUM_PIXELS] = [([int(c*idle_brightness) for c in COLOR_IDLE])] * NUM_STRIP
        strip.show()
    elif mode >= 1:  # If not OFF mode...
        x, y, z = accel.acceleration  # Read accelerometer
        accel_total = x * x + z * z #x axis used for hit and for swing
        accel_yell = y * y + z * z  #y axis used for yell
        # Square root isn't needed, since we're
        # comparing thresholds...use squared values instead.)
        if accel_total > HIT_THRESHOLD:  # Large acceleration on x axis = HIT
            TRIGGER_TIME = time.monotonic()  # Save initial time of hit
            play_wav(random.choice(hit_sounds))  # Start playing 'hit' sound
            COLOR_ACTIVE = COLOR_HIT  # Set color to fade from
            mode = 3  # HIT mode
        elif mode == 1 and accel_total > SWING_THRESHOLD:  # Mild acceleration on x axis = SWING
            TRIGGER_TIME = time.monotonic()  # Save initial time of swing
            play_wav(random.choice(swing_sounds))  # Randomly choose from available swing sounds
            # make a larson scanner
            strip_backup = strip[0:-1]
            for p in range(-1, len(strip)):
                for i in range(p-1, p+2): # shoot a 'ray' of 3 pixels
                    if 0 <= i < len(strip):
                        strip[i] = COLOR_SWING
                strip.show()
                time.sleep(SWING_BLAST_SPEED)
                if 0 <= (p-1) < len(strip):
                    strip[p-1] = strip_backup[p-1]  # restore previous color at the tail
                strip.show()
            while audio.playing:
                pass # wait till we're done
            mode = 2  # we'll go back to idle mode
        elif mode == 1 and accel_yell > YELL_THRESHOLD:  # Motion on Y axis = YELL
            # run a color down the staff, opposite of power-up
            previous = 0
            audio_start_time = time.monotonic()  # Save audio start time
            play_wav(random.choice(yell_sounds))  # Randomly choose from available yell sounds
            sound_duration = YELL_SOUND_DURATION
            while True:
                time_elapsed = time.monotonic() - audio_start_time  # Time spent playing sound
                if time_elapsed > sound_duration:  # Past sound duration?
                animation_time = time_elapsed / sound_duration  # Animation time, 0.0 to 1.0
                pixel_threshold = int(NUM_PIXELS * animation_time + 0.5)
                num_pixels = pixel_threshold - previous  # Number of pixels to light on this pass
                if num_pixels != 0:
                    # light pixels in YELL_COLOR:
                    strip[previous:pixel_threshold] = [YELL_COLOR] * num_pixels
                    strip.show()
                    previous = pixel_threshold
            mode = 4  # we'll go back to idle mode
        elif mode == 1:
            # Idle pulse
            idle_brightness += idle_increment  # Pulse up
            if idle_brightness > IDLE_PULSE_BRIGHTNESS_MAX or \
               idle_brightness < IDLE_PULSE_BRIGHTNESS_MIN:  # Then...
                idle_increment *= -1  # Pulse direction flip
            # light the ring:
            # light the strip:
            strip.show()
            time.sleep(IDLE_PULSE_SPEED)  # Idle pulse speed set above
        elif mode > 1:  # If in SWING or HIT or YELL mode...
            if audio.playing:  # And sound currently playing...
                blend = time.monotonic() - TRIGGER_TIME  # Time since triggered
                if mode == 2:  # If SWING,
                    blend = abs(0.5 - blend) * 3.0  # ramp up, down
                strip.fill(mix(COLOR_ACTIVE, COLOR, blend))  # Fade from hit/swing to base color
                strip.show()
            else:  # No sound now, but still SWING or HIT modes
                play_wav('idle', loop=True)  # Resume idle sound
                mode = 1  # Return to idle mode
I backtracked and ran each of the propmaker test codes for neopixel, accelerometer and audio and each of them worked just fine.
I’ve disassembled and reassembled the entire project and still cannot get this to work.
Any help would be greatly appreciated!
TheGnomeQueen
Re: Help with propmaker project
by dastels on Fri May 01, 2020 9:22 pm
If you connect USB and open a terminal (or Mu's Serial/REPL pane) what does it output?
Hopefully, it will give you more information on what happened.
dastels
by TheGnomeQueen on Fri May 01, 2020 9:32 pm
dastels wrote:If you connect USB and open a terminal (or Mu's Serial/REPL pane) what does it output?
This is what it says:
Soft reboot
Auto-reload is on. Simply save files over usb to run them or enter REPL to disable.
Code.py output:
File “code.py”, line 16 in <module>
ImportError: no module named audiocore
TheGnomeQueen
by dastels on Sat May 02, 2020 9:30 am
The audiocore module/library is missing from the lib directory it would seem. You say it worked for a while? This could be due to a bug in the earlier version of the bootloader.
If you haven't, you should update your bootloader: https://blog.adafruit.com/2020/04/13/uf2-bootloader-news-downloads-in-circuitpython-org-new-version-for-samd51-m4-boards/
dastels
by TheGnomeQueen on Sat May 02, 2020 8:31 pm
Yes!!! I was using the uf2 file I had already downloaded to my computer. When I deleted it and went back to download it again I noticed there was a new version. Everything is running smoothly. Thank you so much for the guidance.
TheGnomeQueen
by dastels on Sat May 02, 2020 10:26 pm
Excellent! Glad to help.
dastels
