Microcontroller for glasses
by Exodus_AU on Wed May 27, 2020 10:59 pm
Building a pair of glasses with a sensor. obviously form factor is huge issue.
My initial prototype was using a flora which worked really great. I tried slimming it down to a gemma and didnt realise it didnt support serial. I bought a Gemma-M0 which doesn't support SoftwareSerial.h
I need a micro-controller which can work with the SRF01 ultrasonic sensor, the sensor uses single wire TX/RX.
Could the trinket do this?
Exodus_AU
Re: Microcontroller for glasses
by adafruit_support_bill on Thu May 28, 2020 5:39 am
The M0 (including both Gemma and Trinket versions) doesn't need Software Serial. You can create hardware serial ports via SERCOM.
https://learn.adafruit.com/using-atsamd ... yUqmupkmKg
by Exodus_AU on Thu May 28, 2020 6:36 am
Hi, can i use SERCOM to define RX and TX on a single pin? SRF01 uses single wire for this.
Exodus_AU
by adafruit_support_bill on Thu May 28, 2020 6:47 am
I don't know. I am not familiar with the SRF01.
If you need a small form-factor board that can run SoftwareSerial, there is the ItysyBitsy 32U4: https://www.adafruit.com/product/3677
