Did I kill the Itsy or the neopixel?
by hippieninja on Sat Dec 19, 2020 11:37 am
first time post, and first real project in a LONG time...
https://learn.adafruit.com/rezz-inspire ... el-glasses - Made this for my wife, after i got everything wired up, when i was securing the PCBS, the hinge joint broke on my frame, so.... not wanting to resolder on the pcb, i clipped the wires and was going to resolder after i replaced the arm.... realized after i cut the wires and was resoldering, that i forgot to unplug the battery pack..... the unit had been off via the switch the entire time....but now when i turn everything on, the neopixel rings are not coming on..... the itsy boots up and then glows green when i power it up.... but no neopixels anymore....
trying to see if i screwed up and need to reorder something quickly, or what...
thanks in advance
hippieninja
Re: Did I kill the Itsy or the neopixel?
by adafruit_support_bill on Sat Dec 19, 2020 12:29 pm
If the power switch was off (and the trace cut) on the backpack, there should not have been a problem due to the battery. Double check all you solder joints. If you post some nice close-up photos of your soldering and connections, we'll see if wee can spot any potential problems.
