Hello i have a Dstike watch i got from ebay https://www.ebay.com/itm/383846316645. It works and all but its very hard to program for me that is. My skills are in hardware not really software but I'm trying. The watch only contains a esp8266mod and a 1.3" oled looks like it's using a SH1106 library. I have look for one online and found this one https://github.com/wonho-maker/Adafruit_SH1106. It looks like it was based off of adafruit library. But i can not confirm it.
i have tired it and i can not get it to work. I went into the Issues area and posted a problem for a delay problem. I found out the delay is for AVR not a 32bit micro processor. I can not find something that works for the Esp8266 and this display. i know this is not a dafruit product. Can someone please help me?
Joseph
Dstike V1 watch
- josephchrzempiec
Re: Dstike V1 watch
Hello i still can not figure this out. And why i do not get nothing on the screen. I'm posting a code below for this.
I'm not sure what else i can do. I really need help.
Joseph
#include <TimeLib.h>
#include <Wire.h>
#include "SH1106Wire.h"
SH1106Wire display(0x3c, D7, D5); // ADDRESS, SDA, SCL
//SSD1306Wire display(0x3c, D7, D5);
// Include the UI lib
#include "OLEDDisplayUi.h"
// Include custom images
#include "images.h"
// Use the corresponding display class:
// Initialize the OLED display using SPI
// D5 -> CLK
// D7 -> MOSI (DOUT)
// D0 -> RES
// D2 -> DC
// D8 -> CS
// SSD1306Spi display(D0, D2, D8);
// or
// SH1106Spi display(D0, D2);
// Initialize the OLED display using brzo_i2c
// D3 -> SDA
// D5 -> SCL
// SSD1306Brzo display(0x3c, D3, D5);
// or
// SH1106Brzo display(0x3c, D3, D5);
// Initialize the OLED display using Wire library
//SSD1306Wire display(0x3c, D3, D5);
// SH1106 display(0x3c, D3, D5);
OLEDDisplayUi ui ( &display );
int screenW = 128;
int screenH = 64;
int clockCenterX = screenW/2;
int clockCenterY = ((screenH-16)/2)+16; // top yellow part is 16 px height
int clockRadius = 23;
// utility function for digital clock display: prints leading 0
String twoDigits(int digits){
if(digits < 10) {
String i = '0'+String(digits);
return i;
else {
return String(digits);
void clockOverlay(OLEDDisplay *display, OLEDDisplayUiState* state) {
void analogClockFrame(OLEDDisplay *display, OLEDDisplayUiState* state, int16_t x, int16_t y) {
// ui.disableIndicator();
// Draw the clock face
// display->drawCircle(clockCenterX + x, clockCenterY + y, clockRadius);
display->drawCircle(clockCenterX + x, clockCenterY + y, 2);
//hour ticks
for( int z=0; z < 360;z= z + 30 ){
//Begin at 0° and stop at 360°
float angle = z ;
angle = ( angle / 57.29577951 ) ; //Convert degrees to radians
int x2 = ( clockCenterX + ( sin(angle) * clockRadius ) );
int y2 = ( clockCenterY - ( cos(angle) * clockRadius ) );
int x3 = ( clockCenterX + ( sin(angle) * ( clockRadius - ( clockRadius / 8 ) ) ) );
int y3 = ( clockCenterY - ( cos(angle) * ( clockRadius - ( clockRadius / 8 ) ) ) );
display->drawLine( x2 + x , y2 + y , x3 + x , y3 + y);
// display second hand
float angle = second() * 6 ;
int x3 = ( clockCenterX + ( sin(angle) * ( clockRadius - ( clockRadius / 5 ) ) ) );
int y3 = ( clockCenterY - ( cos(angle) * ( clockRadius - ( clockRadius / 5 ) ) ) );
display->drawLine( clockCenterX + x , clockCenterY + y , x3 + x , y3 + y);
// display minute hand
angle = minute() * 6 ;
x3 = ( clockCenterX + ( sin(angle) * ( clockRadius - ( clockRadius / 4 ) ) ) );
y3 = ( clockCenterY - ( cos(angle) * ( clockRadius - ( clockRadius / 4 ) ) ) );
// display hour hand
angle = hour() * 30 + int( ( minute() / 12 ) * 6 ) ;
x3 = ( clockCenterX + ( sin(angle) * ( clockRadius - ( clockRadius / 2 ) ) ) );
y3 = ( clockCenterY - ( cos(angle) * ( clockRadius - ( clockRadius / 2 ) ) ) );
void digitalClockFrame(OLEDDisplay *display, OLEDDisplayUiState* state, int16_t x, int16_t y) {
String timenow = String(hour())+":"+twoDigits(minute())+":"+twoDigits(second());
display->setTextAlignment(TEXT_ALIGN_CENTER);
display->setFont(ArialMT_Plain_24);
display->drawString(clockCenterX + x , clockCenterY + y, timenow );
// This array keeps function pointers to all frames
// frames are the single views that slide in
FrameCallback frames[] = { analogClockFrame, digitalClockFrame };
// how many frames are there?
int frameCount = 2;
// Overlays are statically drawn on top of a frame eg. a clock
OverlayCallback overlays[] = { clockOverlay };
int overlaysCount = 1;
Serial.begin(9600);
Serial.println();
// The ESP is capable of rendering 60fps in 80Mhz mode
// but that won't give you much time for anything else
// run it in 160Mhz mode or just set it to 30 fps
ui.setTargetFPS(60);
// Customize the active and inactive symbol
ui.setActiveSymbol(activeSymbol);
ui.setInactiveSymbol(inactiveSymbol);
// You can change this to
// TOP, LEFT, BOTTOM, RIGHT
ui.setIndicatorPosition(TOP);
// Defines where the first frame is located in the bar.
ui.setIndicatorDirection(LEFT_RIGHT);
// You can change the transition that is used
// SLIDE_LEFT, SLIDE_RIGHT, SLIDE_UP, SLIDE_DOWN
ui.setFrameAnimation(SLIDE_LEFT);
// Add frames
ui.setFrames(frames, frameCount);
// Add overlays
ui.setOverlays(overlays, overlaysCount);
// Initialising the UI will init the display too.
ui.init();
display.flipScreenVertically();
unsigned long secsSinceStart = millis();
// Unix time starts on Jan 1 1970. In seconds, that's 2208988800:
const unsigned long seventyYears = 2208988800UL;
// subtract seventy years:
unsigned long epoch = secsSinceStart - seventyYears * SECS_PER_HOUR;
setTime(epoch);
int remainingTimeBudget = ui.update();
if (remainingTimeBudget > 0) {
// You can do some work here
// Don't do stuff if you are below your
// time budget.
delay(remainingTimeBudget);
Joseph
- mikeysklar
Re: Dstike V1 watch
Joseph,
We don't sell this watch or this exact hardware, but there are some Tindie sites that link to options for programming the older esp8266 Dstrike devices.
https://github.com/SpacehuhnTech/esp8266_deauther
I went with the LilyGo which is ESP32 based supports micropython and has some solid docs. The newer Dstrike models (ESP32) have similar support.
https://github.com/Xinyuan-LilyGO/TTGO_TWatch_Library
https://www.tindie.com/products/ttgo/li ... o-t-watch/
