ARDUINO "Problem uploading to board. "
by Helen_Hats on Thu Feb 04, 2021 12:48 pm
I am attempting to upload the strandtest to my Flora (code on the back is 3720) with Neopixels (V3), and I am continually getting the error of "Problem uploading to board." the LED does turn green on the NeoPixel indictating a connection. My libraries are installed as well, running the latest Arduino program (Arduino IDE 1.8.13) on my Macbook Pro (OS 10.15.7). Also, I am a first timer, so if I am missing anything critical and obvious, please let me know!
Helen_Hats
Re: ARDUINO "Problem uploading to board. "
by dastels on Thu Feb 04, 2021 1:31 pm
First, do you have the board and port set correctly?
If so (feel free to post the output resulting from the attempt to upload) try resetting while it is trying.
dastels
by proximityphm on Wed Mar 31, 2021 7:06 pm
I'm having a similar problem with my Flora..Arduino: 1.8.13 (Mac OS X), Board: "Adafruit Flora"
Sketch uses 6568 bytes (22%) of program storage space. Maximum is 28672 bytes.
Global variables use 181 bytes of dynamic memory.
avrdude: butterfly_recv(): programmer is not responding
Found programmer: Id = ""; type =
Software Version = .; Hardware Version = .
avrdude: error: buffered memory access not supported. Maybe it isn't
a butterfly/AVR109 but a AVR910 device?
this check.
avrdude: error: programmer did not respond to command: leave prog mode
avrdude: error: programmer did not respond to command: exit bootloader
proximityphm
by proximityphm on Wed Mar 31, 2021 7:07 pm
Question: The board is not setup as the only port I see in my macbook is the bluetooth...
proximityphm
by dastels on Wed Mar 31, 2021 7:29 pm
It soulds like your board isn't connecting.
Make sure you have a decent quality data USB cable.
dastels
