Flora + HC-06 Bluetooth
by pat__reis on Wed Feb 17, 2021 12:33 pm
Hi Adafruit! I'm doing a wearable project in which I need the Flora to trigger a vibration motor sent by a VR app (made with Unity and installed on Oculus Quest). HC-06 is working very good with Arduino but somehow not with Flora. (Flora attached to HC-=6 through pins RX and TX on board) As looking into Flora and Serial topics on posts I came across the need of using Serial1. I adapted the code for the following but still no success. Any idea? Thanks in advance!
#define mySerial Serial1
int ledpin=6; // led on D13 will show blink on / off
int BluetoothData; // the data given from Computer
Serial.begin(9600);
Serial.println("Type AT commands!"); // put your setup code here, to run once:
mySerial.begin(9600);
Serial.println("Bluetooth On please press 1 or 0 blink LED ..");
pinMode(ledpin,OUTPUT);
if (mySerial.available()) {
BluetoothData=mySerial.read();
if(BluetoothData=='1') { // if number 1 pressed ….
digitalWrite(ledpin,1);
delay(5000);
Serial.println("LED ON");
if (BluetoothData =='0') { // if number 0 pressed ….
digitalWrite(ledpin,0);
Serial.println("LED  OFF ");
delay(100);// prepare for next data …
pat__reis
