Help with capacitive touch gamepad/piano!
by CookieCat25 on Fri Apr 23, 2021 8:23 pm
Not sure if this is the right place to go, but I'm basically following this tutorial for the gamepad using an Adafruit Flora, however, I eventually plan to have seven keys play a note and for the last pin to be connected to a speaker (a piezo buzzer currently).
Below is the circuit thus far, which aside from the button shapes and placements (and skipping pin 6), it is seemingly identical to the tutorial steps. However, whatever I change the THRESH value to, nothing is entered into the text editor. Apparently having feet on the ground makes a difference, but nothing is working right now. This is the code, if anyone can help or has any other tips please help!
  Example code for a Flora game controller with capacitive touch sensing! Full tutorial and video:
  http://learn.adafruit.com/plush-game-controller/
  Uses Modern Device's Capacitive Sensing library: https://github.com/moderndevice/CapSense
  products from Adafruit!
  Written by Limor Fried & Becky Stern for Adafruit Industries.
  BSD license, all text above must be included in any redistribution
#include <CapPin.h>
#include <Keyboard.h>
CapPin cPin_10 = CapPin(10);    // read pin 10 (D10 on Flora) - connect to NES B
CapPin cPin_9  = CapPin(9);     // read pin 9 (D9 on Flora)   - connect to NES A
CapPin cPin_6  = CapPin(6);     // read pin 6 (D6 on Flora)   - connect to NES Start
CapPin cPin_12 = CapPin(12);    // read pin 12 (D12 on Flora) - connect to NES Select
CapPin cPin_1  = CapPin(1);     // read pin 1 (TX on Flora)   - connect to NES right
CapPin cPin_0  = CapPin(0);     // read pin 0 (RX on Flora)   - connect to NES up
CapPin cPin_2  = CapPin(2);     // read pin 2 (SDA on Flora)  - connect to NES left
CapPin cPin_3  = CapPin(3);     // read pin 3 (SCL on Flora)  - connect to NES down
CapPin pins[] = {cPin_10, cPin_9, cPin_6, cPin_12, cPin_1, cPin_0, cPin_2, cPin_3};
// check http://arduino.cc/en/Reference/KeyboardModifiers for more info on unique keys
// WASD D-pad, select = Return, start = Space, LeftButton = z, RightButton = x
//char Keys[] =   {  'x',    'z',    ' ',     KEY_RETURN,    'd',     'w',    'a',    's'};
// arrow D-pad, select = Return, start = Space, LeftButton = b, RightButton = a
char Keys[] =   {  'a',    'b',    ' ',     KEY_RETURN, KEY_RIGHT_ARROW, KEY_UP_ARROW, KEY_LEFT_ARROW, KEY_DOWN_ARROW};
boolean currentPressed[] = {false, false, false, false, false, false, false, false};
// Capactive touch threashhold, you might want to mess with this if you find its too
// sensitive or not sensitive enough
#define THRESH 500
float smoothed[8] = {0, 0, 0, 0, 0, 0, 0, 0};
void setup()
  //while (!Serial)
  Serial.begin(115200);
  Serial.println("start");
  Keyboard.begin();
void loop()
  for (int i = 0; i < 8; i++) {
    delay(1);
    long total1 = 0;
    long start = millis();
    long total =  pins[i].readPin(2000);
    // check if we are sensing that a finger is touching the pad
    // and that it wasnt already pressed
    if ((total > THRESH) && (! currentPressed[i])) {
      Serial.print("Key pressed #"); Serial.print(i);
      Serial.print(" ("); Serial.print(Keys[i]); Serial.println(")");
      currentPressed[i] = true;
      Keyboard.press(Keys[i]);
    else if ((total <= THRESH) && (currentPressed[i])) {
      // key was released (no touch, and it was pressed before)
      Serial.print("Key released #"); Serial.print(i);
      currentPressed[i] = false;
      Keyboard.release(Keys[i]);
        // simple lowpass filter to take out some of the jitter
        // change parameter (0 is min, .99 is max) or eliminate to suit
        smoothed[i] = smooth(total, .8, smoothed[i]);
        Serial.print(i); Serial.print(": ");
        Serial.print( millis() - start);      // time to execute in mS
        Serial.print("ms \t");
        Serial.print(total);                  // raw total
        Serial.print("\t->\t");
        Serial.println((int) smoothed[i]);       // smoothed
    delay(5);
// requires recycling the output in the "smoothedVal" param
int smooth(int data, float filterVal, float smoothedVal) {
  if (filterVal > 1) {     // check to make sure param's are within range
    filterVal = .999999;
  else if (filterVal <= 0) {
    filterVal = 0;
  smoothedVal = (data * (1 - filterVal)) + (smoothedVal  *  filterVal);
  return (int)smoothedVal;
Circuit thus far, with pin 6 empty as a piezo can be attached to it easily along with the GND
tl;dr short-term want to ensure the code works
long term adapt into functioning like a seven key piano, with pin 6 being the audio output with each key playing notes from pitches.h.
CookieCat25
Re: Help with capacitive touch gamepad/piano!
by CookieCat25 on Sat Apr 24, 2021 4:50 am
Sorry to bump a thread but I've gone over the code and the wiring for this a dozen times now with no problems coming up. If anyone can at least suggest somewhere to better understand what I'm trying to do that would be great, or even just a "oh your ___ is ___". Thanks again!
CookieCat25
by adafruit_support_mike on Tue Apr 27, 2021 9:40 pm
The touchpads in the photo look a bit small.
Try dropping back to a single pin and try a series of larger touchpads. See if that has any effect.
