HI,
May I ask if it is possible to make a Flora Wearable Bluefruit LE Module work with an Adafruit GEMMA v2?
Thanks,
Joshua
Can Flora Wearable Bluefruit LE Module Work with Adafruit GE
- liushuya7
- dastels
Re: Can Flora Wearable Bluefruit LE Module Work with Adafrui
It does not appear to be possible as the Gemma V2 does not seem to make Rx/Tx available on the I/O pads. The Gemma M0, on the other hand, does make Rx/Tx available and should have little trouble working with the BLE module. Plus it's not deprecated like the V2.
- liushuya7
What's the difference between them? They look alike.
- dastels
They are completely different other than the shape/size of the boards. The Gemma V2 is based on the 32u4, a slow, 8-bit microcontroller with very little memory while the M0 is build around a SAMD21 which is a fast, r32-bit MCU with much more memory. Most relevant to your question, the M0 exposes Rx/Tx which is needed to use the BLE module. From C++ they will work pretty much identically while the M0 also provides the ability to do some basic programming using CircuitPython.
- Maker4091
Came here looking to post this exact question.dastels wrote:They are completely different other than the shape/size of the boards. The Gemma V2 is based on the 32u4, a slow, 8-bit microcontroller with very little memory while the M0 is build around a SAMD21 which is a fast, r32-bit MCU with much more memory. Most relevant to your question, the M0 exposes Rx/Tx which is needed to use the BLE module. From C++ they will work pretty much identically while the M0 also provides the ability to do some basic programming using CircuitPython.
Good to know I can use it on the New Gemma MO.
thanks Dave!
