vu-meter baseball hat too bright
- leeberry13
Hi Everyone, I built this project and it works great. However, dance partners say it's blinding them. How would I alter the code to turn down the intensity and get better battery life? I read the page about getting the most battery life but it's beyond me at this point...
- jerryn
Re: vu-meter baseball hat too bright
In your setup section of the sketch, you should be able to set the brightness
the number (64) in this example will set it to 1/4 brightness -- the value can be from 0 (off) to 255 (full)
Put this after the
this came from the "UberGuide" https://learn.adafruit.com/adafruit-neo ... ibrary-use
strip.setBrightness(64);
Put this after the
strip.begin()
- Franklin97355
You might be able to modify setpixelcolor to adjust the output. I have not tried this so I'm just guessing.
- leeberry13
Thanks Jerrlyn, I used that idea and tried to upload to the flora. It can't find the com port. The port is greyed out and down below it says flora on com15. I went into device manager and looked at hidden devices to view the com ports. I have com3, com4, and com5. How do I get around this? I hit re-set on the board as it tried to upload a couple of times to get the computer to find the port, but no luck. Maybe my timing of when to push the button is off? This happened years ago when I first built the hat and I forget how I fixed it. Thanks, lee Windows 10, latest version of every driver and arduino software installed.
- jerryn
I'm sorry, I have no experience with either the Flora or with Windows 10. I hope someone else can offer some suggestions.
- leeberry13
I added the code suggested in the set up section and get this error
'class Adafruit_Neopixel' has no member named 'SetBrightness'
I'm guessing that I needed to add something about SetBrightness somewhere in the define section? Thanks, Lee
