Flora & NeoPixel Ring for Ampli-tie
Wearable electronics: boards, conductive materials, and projects from Adafruit!
RMARS
Post by RMARS »
Is it possible to use NeoPixel Ring 24 x 5050 RGB LED with Flora following the Ampli-Tie project?
Thank you.
Re: Flora & NeoPixel Ring for Ampli-tie
Yes. Programing for the rings is the same as for any other Neopixels. They just happen to be arranged in a circle.
RMARS
Post by RMARS »
Thank you for the prompt reply! New to all this!
I don't have any ribbon cable but have 300v 22AWG stranded wire. Will this work alright for all my connections?
Yes. That should be fine for your connections. Be careful to avoid any stray strands that might cause a short circuit. Solid core is a little easier to work with.
RMARS
Post by RMARS »
Great! Thanks for that. Tomorrow just got a lot more exciting!
Return to “Wearables”
