I have a Monster M4sk and have connected a small 1w speaker to it via the Molex Picoblade connector. The documentation for Monster M4sk mentions enabling the speaker using the SPEAKER ENABLE pin (pin 20). Where is this PIN? How do I enable it?
Monster M4sk Pin 20
- dastels
Re: Monster M4sk Pin 20
Depending on language (for the Mask I'm assuming C++) set the mode of pin 20 to output and its value to HIGH. If you're using CircuitPython create a DigitalInOut on board.SPEAKER_ENABLE and set its direction to OUTPUT and value to True.
- michaelc72
Thanks for the help Dave! I'm using CircuitPython.
I'm sorry, I'm a noob when it comes to CircuitPython. Are there any examples of how to do what you mention? I am currently using Bootloader 3.13 along with the M4 eyes firmware (M4SKEYES.UF2).
- dastels
So you're working in C++ then. The M4Eyes firmware is a complete program... you can't use it with CircuitPython.
- michaelc72
Ok, I understand. I'm assuming the headphone jack will not work with the M4Eyes firmware either, correct?
I'm somewhat familiar with C. Is the M4Eyes source code available? If not, is there no way to have audio when using the M4Eyes firmware?
- dastels
Yes, it's available and designed to be extendable. It depends on what you want to do with the headphone jack.
See https://learn.adafruit.com/adafruit-monster-m4sk-eyes, specifically, https://learn.adafruit.com/adafruit-mon ... ource-code.
