How to set a code to run for certain time
Wearable electronics: boards, conductive materials, and projects from Adafruit!
Ilnowstuffandbbq
Post by Ilnowstuffandbbq »
Hi all! First project with Gemma and Circuit python. A little back story, I have a daughter that struggles with anxiety at night and so I am developing a mindfulness breathing timer that is on for 0.5 seconds and then off for 5 seconds. I would like for it to repeat for 10 minutes and then stop. I have tried adding a delay and a stop.time and a time.sleep but it doesn't seem to be working. The code is taken from the Mindfulness Bracelet tutorial. Any help is appreciated.!
import time
import board
from digitalio import DigitalInOut, Direction
# vibrating disc mini motor disc connected on D2
vibrating_disc = DigitalInOut(board.D1)
vibrating_disc.direction = Direction.OUTPUT
on_time = .5     # Vibration motor run time, in seconds
interval = 2   # Time between reminders, in seconds
start_time = time.monotonic()
while True:
    timer = time.monotonic() - start_time
    if timer >= interval and timer <= (interval + on_time):
        vibrating_disc.value = True
    elif timer >= (interval + on_time):
        vibrating_disc.value = False
Reason: Add code block
dastels
Re: How to set a code to run for certain time
Post by dastels »
What's it doing and/or not doing?
From the look of the code it should buzz for half a second, be quiet for 2 seconds, and repeat.
What you need to add is a way to have it go quiet after 10 minute, as well as a way to start the 10 minute buzz-pause cycle.
Return to “Wearables”
