What's wrong with my FLORA?
Wearable electronics: boards, conductive materials, and projects from Adafruit!
Insert_Name_Here
Post by Insert_Name_Here »
Ok. I just got a FLORA in the mail today.
I setup the Adruino IDE. https://learn.adafruit.com/adafruit-ard ... ot-6-x-ide
I plug the board in.
I select "Adafruit Flora" in the boards menu.
I paste this code in:
#define PIN 8
Adafruit_NeoPixel strip = Adafruit_NeoPixel(1, PIN, NEO_GRB + NEO_KHZ800);
  strip.begin();
  strip.setBrightness(50);
  strip.show(); // Initialize all pixels to 'off'
  // Some example procedures showing how to display to the pixels:
  colorWipe(strip.Color(255, 0, 0), 500); // Red
  colorWipe(strip.Color(0, 255, 0), 500); // Green
  colorWipe(strip.Color(0, 0, 255), 500); // Blue
  rainbowCycle(20);
// Fill the dots one after the other with a color
void colorWipe(uint32_t c, uint8_t wait) {
  for(uint16_t i=0; i<strip.numPixels(); i++) {
      strip.setPixelColor(i, c);
      strip.show();
      delay(wait);
// Slightly different, this makes the rainbow equally distributed throughout
void rainbowCycle(uint8_t wait) {
  uint16_t i, j;
  for(j=0; j<256*5; j++) { // 5 cycles of all colors on wheel
    for(i=0; i< strip.numPixels(); i++) {
      strip.setPixelColor(i, Wheel(((i * 256 / strip.numPixels()) + j) & 255));
    strip.show();
    delay(wait);
// Input a value 0 to 255 to get a color value.
// The colours are a transition r - g - b - back to r.
uint32_t Wheel(byte WheelPos) {
  WheelPos = 255 - WheelPos;
  if(WheelPos < 85) {
   return strip.Color(255 - WheelPos * 3, 0, WheelPos * 3);
  } else if(WheelPos < 170) {
    WheelPos -= 85;
   return strip.Color(0, WheelPos * 3, 255 - WheelPos * 3);
  } else {
   WheelPos -= 170;
   return strip.Color(WheelPos * 3, 255 - WheelPos * 3, 0);
And then when I press upload, the onboard led starts blinking like crazy. And finally, after running it for a few seconds, the IDE(even though the USB cable is hooked up) says the serial port is disconnected.
dastels
Re: What's wrong with my FLORA?
Post by dastels »
First, the "serial port" is does not correlate directly to a physical USB port. I've seen board bounce around between serial ports. Did it program it? Is your code running on the Flora?
Insert_Name_Here
My code is not running.
rpiloverbd
Post by rpiloverbd »
Which OS are you using? Windows or MAC? Are you able to program an ordinary Arduino board (like Uno) from your computer? Kindly try programming an Arduino UNO and also try to program the Flora with a different data cable if possible. These are to be sure where the problem actually exists.
Insert_Name_Here
Linux
Insert_Name_Here
I am able to program an Arduino Uno. Also, this is a brand new USB cable from Adafruit that I literally just got in the mail yesterday. It works to program my CPB. I doubt the cable is the problem.
dastels
Post by dastels »
It sounds like you're doing everything right. Let's try a new board.
Please email [email protected] with a link to this thread, your order number, and request the replacement of one Flora V2.
Insert_Name_Here
Oh come on. That's twice Adafruit has offered me a replacement board. I don't think they could have made that many boards that are broken.
Return to “Wearables”
