I have purchased quite a few Flora boards for a big project, and I have run into three boards now that will power on, but will not Blink on #7 or flash TX or RX. My Sketch that is working fine with other Flora boards will show a grey Port drop down when these certain boards are attached. I have tried resetting and holding reset with power multiple times. I can't ever get it to show up so I can select a port. Any tips?
Flora Not Responding
- rpiloverbd
Re: Flora Not Responding
Sounds like you got some problematic boards. Hope adafruit team will come forward to help you soon.
- Jlewkowitz
It seems to be a 1 bad board for every 3 boards so far.
- Franklin97355
When did you buy the Flora and did they work at any time? Can you post pictures of the Floras that don't work with the package tag so we can investigate the supply?
- adafruit2
(and how many are there total that dont respond?)
- Jlewkowitz
so far. 13 that don't respond at all, and 2 that show up on port, but wont finish an upload.
- adafruit2
ok please post up a pic of one of the non-working one's baggy, theres a WO # on it that can help us track down the issue!
- Jlewkowitz
Here is one of the boards that will not respond.
Is there any thing I can try with the boards that respond, but won't finish an upload?Thanks!
- adafruit2
its been a while since we used a flora, but worth asking - do you need to have it switched ON? can ya try another USB cable/port?
- Jlewkowitz
I'll try all that, but it's strange that over 50 boards worked just fine with the USB cable/port i was using, and it didn't matter if they were switched on or not. The switch seems to function as and on/off for when a battery is hooked up to the JST port. I'm at 18 boards now that do no not respond, and 5 that respond but won't take any code.
- adafruit2
ok np, email support@adafruit for an "RMA FORPHIL" for all the boards that are being difficult. thanks!
