Wearable Car Key Locator?
Wearable electronics: boards, conductive materials, and projects from Adafruit!
Jthenich
Post by Jthenich »
Hi everyone! Is there a way to use circuit playground or a similar wearable to point in the direction or tell the proximity of a device at short range? My goal is something like Tile technology but with a wearable flair that could point with an LED or give hot/cold readings. I’ve looked through a lot of GPS units but am not sure which one would fit my needs the best.
Any help or direction would be very much appreciated.
rpiloverbd
Re: Wearable Car Key Locator?
Post by rpiloverbd »
As your main processor, you may either use Arduino Lilypad: https://www.theengineeringprojects.com/ ... lypad.html
Or Flora: https://www.adafruit.com/product/659
You can close this wearable GPS module: https://www.adafruit.com/product/1059
If you use Flora, you can use its in-built colour changing LED for hot and cold indications. If you use, lilypad, you have to sew separate wearable LEDs with that.
Return to “Wearables”
