Flora can't open device, access is denied
- Vulkan52
Hello, i just buyed a Flora and tried to connect to arduino ide, but it gives me an error. "avrdude: ser_open(): can't open device "\\.\COM8": Access is denied." The flora is on device manager in port 6, the ide says it's on 6 as well, but when i press upload, it gives me that error. I tried a lot of usb cables but it's the same. When i connect the flora to usb the led pwr is on, #7 blinks and RX blinks 2 seconds and then goes off. The flora is On.
- adafruit_support_carter
Re: Flora can't open device, access is denied
This is under Tools -> Port in the Arduino IDE?the ide says it's on 6 as well,
- Vulkan52
Yes, I installed drivers and everything, if I try in other computer it connects as a mouse?? or something like that, cuz it deactivates the touchpad on the notebookadafruit_support_carter wrote:This is under Tools -> Port in the Arduino IDE?the ide says it's on 6 as well,
- Screenshot_2.jpg (64 KiB) Viewed 206 times
Try this trick:
https://learn.adafruit.com/adafruit-fea ... aq-2704880
The FLORA uses a 32u4. So same general recover procedure applies.
- Vulkan52
This is what it gives me, no com port searching, and after a few tries, the second one.
- Screenshot_3.jpg (153.95 KiB) Viewed 201 times
- Screenshot_4.jpg (197.14 KiB) Viewed 201 times
Getting the "Access denied" message typically indicates some other software is interfering and trying to take the COM port.
What operating system is running on the two machines tested?
- Vulkan52
Win10 on bothadafruit_support_carter wrote:Getting the "Access denied" message typically indicates some other software is interfering and trying to take the COM port.
- Vulkan52
Good news, I found the problem... NZXT Cam, why? I don't know, but I closed the app and everything runs fine! found thanks to the little trick
Excellent. Good job finding the culprit. Sometimes it can be really tricky tracking down what is doing the interfering. Glad you got it all working now.
