Not sure where to place this post so please migrate it to the proper place if needed.
I want to use the MacroPad to controlling everything in my smarthome. But it needs portable power and a way to talk to things wireless.
If only the MacroPad had a lipo managment and a ESP s3 for wireless and TLS http connections. I would gladly strap this thing to my forearm or bicep to control all my things.
Keep up the great work, that is all.
MacroPad wireless
- davidb21
Re: MacroPad wireless
If I wanted to do this today I could use one of my MagTags and have the MacoPad 2040 talk to it using the usb - C sending serial commands.
A guess another route would be to wake the MagTag when ready to transmit then have them talk using I2C???
Any other alternatives that I have overlooked?
- davidb21
Would there be a way to have the magtag send power to the MacroPad 2040 using the USB C PD?
- davidb21
Thoughts on placing the QT Py ESP32 S2 WiFi DevBoard on the MacroPad? It has a I2C but perhaps it would be better make a physical connection using the GPIO pins, any ideas?
It would probably be easier to connect the Macropad to a RasPi Zero-W, then let the RasPi control the home automation through its Wifi interface.
For battery power, a PowerBoost 500C should be able to keep both boards happy, and has an onboard LiPo charger:
https://www.adafruit.com/product/1944
- davidb21
Great idea and I have a bunch of those in list of parts. The form fact is good and I could the pi zero with a read only file system. I'm thinking then just use one GPIO from the macro pad sending commands to the pi zero. Anything I may be missing? Thanks for the suggestion!
- davidb21
Also, should I be able to use the port on the macropad for serial or the hardware dedicated for only I2C?
If you’re using a RasPi you can connect the MacroPad through a USB cable, and use the Serial interface.
