Windows Gemma-ified Arduino - Expected 4 got 5 errors
by bristolfashion on Thu Mar 13, 2014 6:13 am
We have been preparing lots of Windows devices (Vista, XP, Win7) to run Gemma as part of a series of workshops. Gemma is really great and inexpensive for teaching code etc.
We use the Adafruit Gemma-ified download of Arduino. The installations go pretty smoothly, but we almost always have to do the Chip Erase Delay fix in avrdude.conf or we get Expected 4 got 5 errors when trying to upload. Making that change provides an instant fix.
So, the question is, would it be a good idea to make that change in Adafruit's Gemmified Arduino download, rather than some/many users having to do it every time? Or, would that then cause problems for other devices?
David
NB We keep a webpage recording some of our install issues and fixes, which I give below in case it is useful to others. :D
http://www.electronicfashion.co.uk/technical/gemmasuccessfulwindowsinstallations.htm
bristolfashion
Re: Windows Gemma-ified Arduino - Expected 4 got 5 errors
by adafruit_support_bill on Thu Mar 13, 2014 6:34 am
Thanks for the suggestions and the link. I will pass them along to the team. :)
by adafruit on Thu Mar 13, 2014 1:42 pm
Thanks, can you test out our new 3/13/14 windows download here?
http://learn.adafruit.com/introducing-g ... rduino-ide
it should have that already in it :) let us know if it doesnt automatically work for you!
by bristolfashion on Fri Mar 14, 2014 5:52 am
Brilliant. I will download and let you know how we get on.
bristolfashion
by bristolfashion on Fri Mar 14, 2014 3:41 pm
OK. So I downloaded the new version with yesterday's date. As far as I can see the avrdude.conf file still has the chip_erase_delay for attiny85 set at the old value of 90000. So we got the usual expected 4 got 5 problems until we changed it as below.
" .. go to a section called 'attiny85' then a few lines under that see 'chip erase delay = 90000' . Change the 9 to a 4. "
So, not quite there. Sorry. :(
bristolfashion
by adafruit on Sat Mar 15, 2014 10:01 pm
ooof of course did not save the file. can you try again? same download, i just replaced it!
by bristolfashion on Mon Mar 17, 2014 11:17 am
Fantastic. Just tried it on a previously untouched PC (Win 7 Pro) and the install was flawless - no need for any changes. Gemma was uploaded to and blinking to order in a few minutes from starting. Many thanks. :D :D :D
bristolfashion
