Trinket vs Trinket M0
by Stephen012343 on Wed Nov 07, 2018 5:53 pm
Is it M zero or M oh ?
What is the difference / advantages / disadvantages between Trinket and Trinket M0.
What does M0 mean?
I probably mistakenly ordered the wrong Trinket due to their not being well defined and obvious info for a newbie.
Totally new to these Adafruit products. A selection chart would solve this.
Stephen012343
Re: Trinket vs Trinket M0
by adafruit_support_bill on Wed Nov 07, 2018 6:05 pm
The M0 version uses a much more advanced processor that has native USB capability - vs the USB software emulation done in the original Trinket. This makes for more reliable and easier to use USB operation - as well as eliminating the limitations on use of pins 3 and 4. The M0 also has higher speed and more memory.
by Stephen012343 on Wed Nov 07, 2018 6:14 pm
You are talking way above a newbie's head. What does " as well as eliminating the limitations on use of pins 3 and 4. " mean to me ?
I am trying to make something that will play a variable (based on analog input level) audio tone (output to a transducer) when a digital input signal (on/off) changes.
Will the Trinket 5V work for this ?
Stephen012343
by adafruit_support_bill on Wed Nov 07, 2018 7:17 pm
This is described in the guide: https://learn.adafruit.com/introducing- ... b-pins-3-9
That would require only 2 pins - and not very extensive programming. So the 5v Trinket should handle it.
by jc27 on Thu Nov 08, 2018 5:53 pm
I am curious what advantage I would get (if any) were I to switch to the Mo from the trinket pro for my servo project. I currently use the pro to detect a wireless transmitter output to rotate a servo. Would the trinket M0 do this job better than the trinket pro?
jc27
by adafruit_support_bill on Thu Nov 08, 2018 8:15 pm
@ jc27 - If the Trinket Pro is working Ok for you now, the M0 will not likely add any benefit.
