CircuitPython Trinket M0 supports i2c slave?
by itsnotme on Sat Apr 13, 2019 10:40 pm
I am trying to use the Trinket M0 as a i2c slave in circuitpython but I don't seem to be able to find any documentation of where the i2cslave module is located?
Or is it not possible to do i2cslave on the Trinket M0?
itsnotme
Re: CircuitPython Trinket M0 supports i2c slave?
by adafruit_support_mike on Mon Apr 15, 2019 12:10 am
The Wire library supports operation as an I2C slave, you just use a different set of functions.
Once you've selected the Trinket M0 as your target device, the File->Examples menu will have a section labeled 'Examples for Adafruit Trinket M0'. Under the Wire item you'll find examples named 'slave_receiver' and 'slave_sender'.
by itsnotme on Mon Apr 15, 2019 1:51 am
Are you referring to the Arduino Wire library?
I was hoping there would be something in the CircuitPython libraries to use?
itsnotme
by itsnotme on Mon Apr 15, 2019 1:57 am
For some further clarification I was referring to this: https://circuitpython.readthedocs.io/en ... nit__.html
I can't seem to tell if this is available to the Trinket M0 board?
itsnotme
by danhalbert on Mon Apr 15, 2019 10:33 am
I2CSlave is not included in the Trinket M0 build for space reasons. You could build your own version of CircuitPython for Trinket M0 which removed other functionality to make room for I2CSlave. For instance, if you don't need analogio or pulseio, you could turn those off.
Take a look here and see if you want to do this, and we can provide more guidance if you do: https://learn.adafruit.com/building-circuitpython
danhalbert
