trouble interpreting analogRead
by mdikov on Fri Jun 14, 2019 11:44 am
I have been having some issues interpreting the value analogRead in my program to a trinket 3v. When I use the USB plug as power all works fine, but when I use 5v power through the BAT pin the behavior changes and the program goes to the top if branch.
 if(switchOne > ON && switchTwo > ON) {
    rainbowHold(10);
    return;
What am I missing? I am thinking the numbers I get from analogRead are different with each power source, but they should be stable, no?
Find attached the pin connections. On #1 I have the neopixel jewels; #3 and #4 are the buttons which are directly connecting to ground (no extra resistors); BAT for USB power, Ground.
#define SWITCH_PIN_ONE 2
#define SWITCH_PIN_TWO 3
int ON = 1000;
  int switchOne = analogRead(SWITCH_PIN_ONE);
  int switchTwo = analogRead(SWITCH_PIN_TWO);
    rainbowHold(10);
    return;
  if(switchOne > ON) {
    solidWhite(0);
    return;
  if (switchTwo > ON) {
    fruit(50);
    return;
  solidBlack(10);
mdikov
Re: trouble interpreting analogRead
by franklin97355 on Fri Jun 14, 2019 12:24 pm
What battery are you running the Trinket on? If you are running on a LiPo (3.7v) you don't have 5-volts available.
franklin97355
by adafruit_support_bill on Fri Jun 14, 2019 12:28 pm
Please post a photo or diagram showing how your switches are connected.
And please post the complete code so we can see if and/or how you have configured your pins.
A more fundamental question is: why are you using analogRead to read switch states? digitalRead would be more appropriate for that.
by mdikov on Fri Jun 14, 2019 3:07 pm
franklin97355 wrote:What battery are you running the Trinket on? If you are running on a LiPo (3.7v) you don't have 5-volts available.
No battery, USB cable to a USB wall charger. The lamp is stationary.
mdikov
by mdikov on Fri Jun 14, 2019 3:12 pm
adafruit_support_bill wrote:Please post a photo or diagram showing how your switches are connected.
Well about digital vs analog... we don't know the things we don’t know :) Now that you said it totally makes sense. Here is the code.
Don’t have the diagram on hand but the wiring picture is above. Basically I have a 3 way lamp switch with 4 states hooked up to 3,4 and the common end to 5v/BAT.
#define PIXEL_PIN 1
#define NUMBER_OF_PIXELS 32
Adafruit_NeoPixel pixels = Adafruit_NeoPixel(NUMBER_OF_PIXELS, PIXEL_PIN);
uint32_t orange = pixels.Color(255, 128, 0),
         lyme = pixels.Color(0, 255, 0),
         lemon = pixels.Color(255, 255, 0),
         grapefruit = pixels.Color(255, 0, 128);
int ON = 1020;
  pixels.begin();
  solidWhite(20);
  solidBlack(20);
  // runs #3
    rainbowHold(10);
    return;
  // runs #1
    solidWhite(0);
    return;
  // runs #2
    fruit(50);
    return;
  solidBlack(10);
void solidWhite(uint8_t wait) {
  uint8_t  i;
  pixels.setBrightness(120);
  for(i=0; i<pixels.numPixels(); i++) {
      pixels.setPixelColor(i, pixels.Color(250, 250, 250));
  pixels.show();
  delay(wait);
void solidBlack(uint8_t wait) {
  uint8_t  i;
  pixels.setBrightness(0);
      pixels.setPixelColor(i, pixels.Color(0, 0, 0));
  pixels.show();
  delay(wait);
void fruit(uint8_t wait) {
  uint8_t  i;
  int      firstJewel = 6,
           secondJewel = 13,
           thirdJewel = 20;
  for(i=0; i < pixels.numPixels(); i++) {
    if(i <= firstJewel) {
      pixels.setPixelColor(i, orange);
    } else if(i > firstJewel && i <= secondJewel) {
      pixels.setPixelColor(i, lyme);
    } else if(i > secondJewel && i <= thirdJewel) {
      pixels.setPixelColor(i, lemon);
    } else {
      pixels.setPixelColor(i, grapefruit);
  pixels.show();
  delay(wait);
void rainbowHold(uint8_t wait) {
  uint16_t r, j;
  for(j=0; j<256*1; j++) { // 3 cycles of all colors on wheel
    for(r=0; r< pixels.numPixels(); r++) {
      pixels.setPixelColor(r, Wheel(((r * 256 / pixels.numPixels()) + j) & 255));
      if(switchTwo < ON) {
        return;
    pixels.show();
    delay(wait);
// Input a value 0 to 255 to get a color value.
// The colours are a transition r - g - b - back to r.
uint32_t Wheel(byte WheelPos) {
  if(WheelPos < 85) {
   return pixels.Color(WheelPos * 3, 255 - WheelPos * 3, 0);
  } else if(WheelPos < 170) {
   WheelPos -= 85;
   return pixels.Color(255 - WheelPos * 3, 0, WheelPos * 3);
  } else {
   WheelPos -= 170;
   return pixels.Color(0, WheelPos * 3, 255 - WheelPos * 3);
mdikov
by XRAD on Fri Jun 14, 2019 5:35 pm
Instead of 'ON,' consider adding switch 'states' before setup. Look at this example:
https://www.arduino.cc/en/tutorial/button
Then you can add all the T /F's (0,1 or boolean) you want to the if's( ) to make something happen.....
and you can do something like:
if ((a ==True) && (B == True)) { do something} // etc.....
XRAD
by adafruit_support_bill on Fri Jun 14, 2019 6:54 pm
So when the switch is open, the pin is 'floating' and the value is 'undefined'.
See lesson 6 for a tutorial on how to wire and program switch inputs: https://learn.adafruit.com/adafruit-ard ... s/overview
