No serial USB port for mac in Arduino IDE
by jwbacn on Sat Jun 29, 2019 10:55 pm
I have an Arduino Trinket 5v I am trying to connect to my computer via USB. When I click Tools>Port there are no USB options listed. It shows multiple /dev/cu.XXXX options which are bluetooth related.
Screen Shot 2019-06-29 at 7.50.22 PM.png (1002.52 KiB) Viewed 227 times
I have tried on my 2016 Macbook Pro Mojave with no luck, and have looked on StackExchange and have tried installing CH 34X drivers to no avail. I have also tried on a 2013 Macbook Air Mojave and it doesn't work.
I have downloaded the trinket libraries and have selected the board as 'Pro Tinket 5V/16MHz (FTDI)' although I don't think this is related to the port. I have tried multiple cables and am using one that *does connect* to an Adafruit Pyportal.
The tutorial I was following says no drivers required on the mac. Thanks for your help!
jwbacn
Re: No serial USB port for mac in Arduino IDE
by adafruit_support_mike on Sun Jun 30, 2019 1:19 am
The Pro Trinket doesn't register as a Serial Port in the Arduino IDE.
The board doesn't have any real USB hardware, the bootloader just emulates a low-speed USB connection long enough to upload firmware. The details are explained in the tutorial:
https://learn.adafruit.com/introducing- ... rduino-ide
by jwbacn on Sun Jun 30, 2019 4:03 pm
Hey Mike thanks for your reply. I'm still confused. Can I use the microUSB at all? Or do I need to purchase something else like this?
https://www.adafruit.com/product/954
The tutorial didn't list that as a necessary part.
Also I'm using Arduino 1.8.9 - is the bug referenced in your link squashed in this newer version?
There's nothing referenced in the tutorial about this (https://learn.adafruit.com/bike-wheel-p ... y/overview).
jwbacn
by adafruit_support_mike on Mon Jul 01, 2019 1:21 am
You can program the Pro Trinket through the micro-USB jack without using an external USB-to-Serial converter. You just have to reset the board manually to force the bootloader to launch and start emulating a USB connection when the IDE is ready to upload the firmware.
It's all covered on the tutorial page linked above.
by philosocrates on Fri Aug 16, 2019 5:03 pm
Same issue on my Mac. Same Mac that he's been used to program 2 5v Pro Trinkets in the past. Cable is good. The IDE just can't find it.
Arduino: 1.8.9 (Mac OS X), Board: "Arduino/Genuino Uno"
Sketch uses 3912 bytes (12%) of program storage space. Maximum is 32256 bytes.
Global variables use 41 bytes (2%) of dynamic memory, leaving 2007 bytes for local variables. Maximum is 2048 bytes.
/Users/mikemadden/Library/Arduino15/packages/arduino/tools/avrdude/6.3.0-arduino14/bin/avrdude -C/Users/mikemadden/Library/Arduino15/packages/arduino/tools/avrdude/6.3.0-arduino14/etc/avrdude.conf -v -patmega328p -carduino -P/dev/cu.Bluetooth-Incoming-Port -b115200 -D -Uflash:w:/var/folders/px/dfyfbpq56wv9kxpwrwc3gpmw0000gn/T/arduino_build_212139/Tauren.ino.hex:i
avrdude: Version 6.3-20171130
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "/Users/mikemadden/Library/Arduino15/packages/arduino/tools/avrdude/6.3.0-arduino14/etc/avrdude.conf"
User configuration file is "/Users/mikemadden/.avrduderc"
User configuration file does not exist or is not a regular file, skipping
Using Port : /dev/cu.Bluetooth-Incoming-Port
Using Programmer : arduino
Overriding Baud Rate : 115200
avrdude: stk500_recv(): programmer is not responding
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x00
avrdude done. Thank you.
Problem uploading to board. See http://www.arduino.cc/en/Guide/Troubleshooting#upload for suggestions.
philosocrates
