How to detect programmatically when a RGBW LED is disconnect
Re: How to detect programmatically when a RGBW LED is discon
by kcl1s on Thu Nov 07, 2019 10:54 am
I am trying to make a rectangular LED matrix which can function as a drawing board. All pixels are off initially. A pointer (stick) with a magnet on the tip can be used to draw curves with different colors and intensities on the board. A BlueFruit Feather will be good for that. That's it in a nutshell. I can see many different practical applications for this kind of a "drawing board".
I applaud your DIY attitude and ingenuity. I am the last person to throw cold water on an innovative Arduino project and wish you well. Saying this very low resolution and not so inexpensive project has many different practical applications may be a step too far. Touch screen tablets and other touch technology in my opinion will be better for a "drawing board" type display.
I can see your techniques being useful on interactive displays of Neopixel 'routes' seen in museums and nature centers where fewer hall effect sensors could activate a section of pixels.
These are just my thoughts and I wish you good luck with your project.
Keith
kcl1s
by XRAD on Thu Nov 07, 2019 11:47 am
As for the LEDs as input/output devices, it will be great if someone with more programming experience than me writes a program to compare the original "driver program" with the one that is active at a point in time after the n-th bit has been "cut out".
I don't think you will get anyone to write this program for you unless you pay $$. Even then there may be some proprietary info in the neopixel driver chip....
You may consider a large resistive touch screen as an input device. Then you can build your code and move to other sensors down the road.......
XRAD
by vnenov on Sat Nov 23, 2019 11:55 am
Hi guys, I have a follow up question regarding the speed of reading data over I2C.
I decided to follow Eric's suggestion and use seesaw to get more pins for my Hall switches. I have connected the seesaw as an I2C slave to a Feather32u4. When I run the loop in my code I noticed that it has a refresh cycle of 1 Hz (looking at the print statements in the Serial monitor). I have NO 1 second delays in my code at all. The loop runs very fast if I don't have the seesaw connected to the Feather and have the LED strip and Hall switches connected directly to pins on the Feather. Why is this happening? What am I missing?
I have tried setting the Wire.setClock(clockFrequency); with different clock frequencies (e.g. 1000000L, 400000L ), but it makes no difference. Still reading the seesaw pins at about 1Hz. Is the reading speed a limitation of the seesaw or the Feather32u4? I need to be able to read them at least at 10Hz frequency. How do I do that? Can anyone please help?
vnenov
