Eagle Outline for Trinket
by Riffelrw on Fri Feb 07, 2020 9:36 pm
I've designed a number of boards to work with a feather - but i'm looking to build an adapter so i can use the same boards with a trinket (where applicable). Is there an eagle footprint available for Eagle? I have been using one for the feather that was in microbuilder.lbr but I don't see a trinket.
I could build it myself but thought someone might have already.
Riffelrw
Re: Eagle Outline for Trinket
by franklin97355 on Fri Feb 07, 2020 11:28 pm
franklin97355
by Riffelrw on Sat Feb 08, 2020 12:11 pm
I had looked at that and downloaded the files already, but it's the PCBA layout so it's not a "component" in alibrary i can drop on to another design. The dimensions are there so I could build up my own part in the library editor, I was just being lazy to see if someone else had done this before..... But at least everything is there that I would need to do the work....
Thanks,
Rich
Riffelrw
by adafruit_support_mike on Sun Feb 09, 2020 3:25 am
It's easiest just to use a couple rows of pin header and label the signals.
by srklipst on Thu Sep 16, 2021 3:42 pm
franklin97355 wrote:Will any of this help? https://github.com/adafruit/Adafruit-Trinket-PCB
I'm looking for the locations of the drills for mounting onto another board. The files I downloaded from Github are not readable with Eagle version 9. Any help from Adafruit on this?
srklipst
by srklipst on Thu Sep 16, 2021 3:51 pm
Hanh... I apologise. The error is mine; the file was saved as some flavor of HTML instead of .brd , so of course it wouldn't read. I got it right this time.
Many thanks to Adafruit for making this available.
srklipst
by franklin97355 on Thu Sep 16, 2021 3:54 pm
You might try to update Eagle. I was able to view the brd files with 9.6.2
franklin97355
by srklipst on Thu Sep 16, 2021 4:00 pm
franklin97355 wrote:You might try to update Eagle. I was able to view the brd files with 9.6.2
Yeah I figured out my error. I first didn't save the file as 'raw,' so my browser interpreted it as some kind of HTML. But I realised my error and fixed it.
Thank you all the same, for your reply. :)
srklipst
