Voltage on Analog Pins with nothing plugged in?
Adafruit's tiny microcontroller platform. Please tell us which board you are using.
eat_sleep_code
Post by eat_sleep_code »
I have the code similar to the following:
pin1 = AnalogIn(board.D1)
pin1Threshold = 1.6
def getVoltage(pin):
    voltage = (pin.value * 3.3) / 65536
    return voltage
def gitPin(pin)
    if pin == 1:
        return pin1Threshold, getVoltage(pin1)
pinNumber = 1
threshold, voltage = getPin(pinNumber)
print('Threshold: ', threshold)
print('Voltage: ', voltage)
In my actual code, I have this for pins 1 - 4, but edited here for brevity.
The voltage of the pins with nothing plugged in varies between 0.8 to 2.2volts with nothing plugged in. This is with just a Trinket M0 plugged into the desktop using the micro USB.
Why is this? I would think the voltage should be 0 if there is nothing plugged in?
I am running the latest (as of yesterday) production release versions of both CircuitPython and the boot loader (was happening on the original version too, upgraded to see if it was a bug).
Re: Voltage on Analog Pins with nothing plugged in?
With nothing connected, the inputs will 'float' and the values will be unpredictable. If you want to see a 0, you need to tie the input to ground either directly or via a pulldown resistor.
eat_sleep_code
maesoph
Post by maesoph »
Fair warning: Mechanical engineer that thinkers with electronics.......
Working with a Trinket M0 - does it have a built in pull up / pull down resistor???
I've tried both schemes and the voltage just seems to float about in the middle of the range.. Assuming the answer is likely "NO"..... What is the minimum resistance that should be used for pull up / pull down resistors?? I have a very limited selection of resistors - don't think I have anything in the neighborhood of 10k ohms...
These processors do have built-in pullups, but you need to explicitly enable them with a PinMode statement: https://www.arduino.cc/reference/en/lan ... o/pinmode/
The exact value is usually not critical. 10K is commonly used. 1K would be considered a fairly 'strong' pullup. 100K would be on the 'weak' side. The internal pullups are typically in the 20K Ohm range.
Return to “Trinket ATTiny, Trinket M0”
