PRO TRINKET 5V FLICKERING NEOPIXELS
by Nalath on Wed Oct 13, 2021 10:30 am
Dear Support Team,
Hope you are doing well! I wanted to get your support for a weird issue I have on my circuit. Thanks in advance!
Material:
Li-ion battery 3.7V/6600 mAh + PowerBoost 500 Basic supplying the whole thing with 5V, 1µF Capacitor between +/-
Adafruit Pro Trinket 5V
RGB NeoPixels groups (1 x 2 neo, 3 x 5 neo & 1 x 9 neo), 470 Ohm resistor on the data pin
Issue:
When pushing red, blue or green or any combinaison of two colors, it works fine. However, when pushing the three colors together I observe some flickering green in the overall white the neos produce. Only the groups of 5 NeoPixels get this issue (pins 4, 5, 6), the group of 9 (pin 3) and the group of 2 (pin 8) turn white with no problem... I tried to switch pins already, same issue...
I will try to use other group of five as some neopixel could be damaged in those chains... This is the only issue I can come up with...
Any idea or experience sharing about the same?
Thanks a lot in advance!
Nalath
Adafruit_NeoPixel STRIP_CRISTAL_1 = Adafruit_NeoPixel(5, 4, NEO_GRB + NEO_KHZ800);
Adafruit_NeoPixel STRIP_CRISTAL_2 = Adafruit_NeoPixel(5, 5, NEO_GRB + NEO_KHZ800);
Adafruit_NeoPixel STRIP_CRISTAL_3 = Adafruit_NeoPixel(5, 6, NEO_GRB + NEO_KHZ800);
pinMode(4, OUTPUT);
pinMode(5, OUTPUT);
pinMode(6, OUTPUT);
STRIP_CRISTAL_1.begin();
STRIP_CRISTAL_2.begin();
STRIP_CRISTAL_3.begin();
STRIP_CRISTAL_1.setBrightness(bright);
STRIP_CRISTAL_2.setBrightness(bright);
STRIP_CRISTAL_3.setBrightness(bright);
STRIP_CRISTAL_1.show();
STRIP_CRISTAL_2.show();
STRIP_CRISTAL_3.show();
Nalath
Re: PRO TRINKET 5V FLICKERING NEOPIXELS
by adafruit_support_bill on Wed Oct 13, 2021 10:38 am
You only posted a fragment of your code. But from your description I count 26 pixels. Driving them all at full intensity white would try to pull about 1500mA. That is more than the PowerBoost 500 can source.
by Nalath on Wed Oct 13, 2021 4:53 pm
Thanks Bill!
Actually I did not want to flood with the entire code, but you get a good point here. The PowerBoost 500 would not be sufficient even with the lower intensity I did set up... I did test by exchanging with a PowerBoost 1000C and actually the Cristal_3 behaved as expected while Cristal_2 and Cristal_1 did flicker again... So I guess this would cause a drop in the supply tension which would result in the unstable behaviour or the NeoPixels (like the classic 3.3V).
So I guess I will need to develop another animation that would be supported by the hardware and drain less current...
Thanks again for your efficient and swift response :)
Nalath
