Hardware Interrupt?
Hardware Interrupt?
by JohnKnoll on Sun May 15, 2022 10:50 pm
I have a project where I'm using a Trinket M0 to count logic pulses coming in from another microcontroller, a Teensy 4.1. Both devices are powered from the same source and their grounds are connected.
I'm feeding the signal from the Teensy to pin 1 , and attaching an interrupt routine to that pin:
volatile int motorpositioncounter1;
int motorpos;
const int xstepPin = 1;
const int xdirPin = 2;
void countpulse1(void)
if (digitalRead(xdirPin)) motorpositioncounter1--;
else motorpositioncounter1++;
void setup()
pinMode(xstepPin, INPUT);
pinMode(xdirPin, INPUT);
// setup interrupt to count pulses
motorpositioncounter1 = 0;
attachInterrupt(digitalPinToInterrupt(xstepPin), countpulse1, FALLING);
motorpos = 0;
void loop()
// Get the motor position.
noInterrupts();
motorpos = motorpositioncounter1;
interrupts();
// display it
DisplayMotorPosition(motorpos);
delay(10);
This compiles and runs without error, but the pulses are not getting counted. This exact same setup works perfectly with a Teensy LC, but doesn't work with the Trinket M0. The pinout card indicates that I should be able to trigger hardware interrupts on pin1 in this manner, but it doesn't appear to be working. Is there something I'm not doing right here?
JohnKnoll
Re: Hardware Interrupt?
by JohnKnoll on Mon May 16, 2022 1:34 am
Sorry, false alarm. It is working. Like an idiot I was hooked up to the wrong pin on the Teensy.
JohnKnoll
