I tried using the serial "Serial debugging with Gemma" Calibrate sensors on GEMMA and Trinket! as descibed under:
https://learn.adafruit.com/serial-debug ... a/overview
I use Arduino 1.8.5. for trinket 8MHz ; Programmer: i selected USBtinyISP.
I tried to use, but it does not work. Connecting USB-serial to Pins 0 and 1 the trinket sends out just 00.
During programming the following message comes up:
Der Sketch verwendet 2034 Bytes (38%) des Programmspeicherplatzes. Das Maximum sind 5310 Bytes.
Globale Variablen verwenden 126 Bytes des dynamischen Speichers.
avrdude: error: usbtiny_transmit:
this check.
Hopefully you can add information how to use succesful.
Trinket, Gemma serial debugging
- adafruit_support_carter
Re: Trinket, Gemma serial debugging
Post a photo of your setup showing how you have everything connected. What sketch were you trying to run?
- whz
I updated library.
It is working now.
Thank you.
It is working now.
Thank you.
