possible defective TrinketMO
- twalker
I recently received my two Trinket MO boards. One works great! But, the other does not. When USB is plugged in, the blue light turns on and immediately turns off. The green power light remains on. Unfortunately, I did not test it prior to soldering on the headers, so it is possible it may have been damaged during this process. I have examined the header solder joints under considerable magnification and do not see any indication of shorting or overheating. Is there any possibility this board is still OK? How could I check it? Thanks.
Re: possible defective TrinketMO
Does anything happen if you double-click the reset button on the one that doesn't work?
- twalker
No, there is no visible response to double-click of the reset pin.
Thank you. It sounds like something is wrong with that one’s bootloader.
Send a note containing a link to this page and your order number to [email protected]. The folks there will get you a new Trinket M0.
- impossibledev
might be a tad late, but for reference in case this comes up in a search later on, I managed to fix my trinket that shipped with a faulty bootloader: viewtopic.php?f=52&t=140080#p696732
