Hello! I'm new to this forum and to the Adafruit Products :)
I've bought a Trinket V5 Pro, 2 strip Neopixel Leds and a Power Boost.
Everything works fine with the connections and weldings but I've some problems with the Trinket and the Arduino IDE program.
I've a Windows 10 PC and I've downloaded the Drivers (The USB port show tinyIsp), I've already dowloaded library and I have the Trinket on the board settings.
But when I try to upload any code, the program just say to me that I've to select a port. The port option is grey. Even if I try to upload with Programmer I get the same error.
I've tried everything but nothing change :(
Can Anyone help me?
P.S. I've tried also on a notebook with Windows 7, but I have the same problem ;_;
Thanks a lot! ^_^
Pro Trinket - 5V 16Mhz Port Problems
Re: Pro Trinket - 5V 16Mhz Port Problems
If you are programming via the USB jack on the board, there is no port. You use the "USBTinyISP" programer as described in the documentation.
https://learn.adafruit.com/introducing- ... -setup-7-3
If you are using an FTDI cable, then you will need to select the port created for the FTDI cable.
https://learn.adafruit.com/introducing- ... in-ide-6-6
- Zarek85
Hello! Thanks for the Answer :)
I've already did it, but the program just give me this port error:
- Immagine.jpg (345.66 KiB) Viewed 242 times
Please cut and paste the actual text from the IDE. The screen shot is not legible.
- Zarek85
It's a bit long ^^''
C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.15.0_x86__mdqgnx93n4wtt\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.15.0_x86__mdqgnx93n4wtt\hardware -hardware G:\Users\Stefano\Documents\ArduinoData\packages -tools C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.15.0_x86__mdqgnx93n4wtt\tools-builder -tools C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.15.0_x86__mdqgnx93n4wtt\hardware\tools\avr -tools G:\Users\Stefano\Documents\ArduinoData\packages -built-in-libraries C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.15.0_x86__mdqgnx93n4wtt\libraries -libraries G:\Users\Stefano\Documents\Arduino\libraries -fqbn=adafruit:avr:protrinket5 -ide-version=10807 -build-path C:\Users\Stefano\AppData\Local\Temp\arduino_build_774576 -warnings=none -build-cache C:\Users\Stefano\AppData\Local\Temp\arduino_cache_655027 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avrdude.path=C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.15.0_x86__mdqgnx93n4wtt\hardware\tools\avr -prefs=runtime.tools.avrdude-6.3.0-arduino14.path=C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.15.0_x86__mdqgnx93n4wtt\hardware\tools\avr -prefs=runtime.tools.avr-gcc.path=C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.15.0_x86__mdqgnx93n4wtt\hardware\tools\avr -prefs=runtime.tools.avr-gcc-5.4.0-atmel3.6.1-arduino2.path=C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.15.0_x86__mdqgnx93n4wtt\hardware\tools\avr -prefs=runtime.tools.arduinoOTA.path=C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.15.0_x86__mdqgnx93n4wtt\hardware\tools\avr -prefs=runtime.tools.arduinoOTA-1.2.1.path=C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.15.0_x86__mdqgnx93n4wtt\hardware\tools\avr -verbose C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.15.0_x86__mdqgnx93n4wtt\examples\01.Basics\Blink\Blink.ino
C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.15.0_x86__mdqgnx93n4wtt\arduino-builder -compile -logger=machine -hardware C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.15.0_x86__mdqgnx93n4wtt\hardware -hardware G:\Users\Stefano\Documents\ArduinoData\packages -tools C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.15.0_x86__mdqgnx93n4wtt\tools-builder -tools C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.15.0_x86__mdqgnx93n4wtt\hardware\tools\avr -tools G:\Users\Stefano\Documents\ArduinoData\packages -built-in-libraries C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.15.0_x86__mdqgnx93n4wtt\libraries -libraries G:\Users\Stefano\Documents\Arduino\libraries -fqbn=adafruit:avr:protrinket5 -ide-version=10807 -build-path C:\Users\Stefano\AppData\Local\Temp\arduino_build_774576 -warnings=none -build-cache C:\Users\Stefano\AppData\Local\Temp\arduino_cache_655027 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avrdude.path=C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.15.0_x86__mdqgnx93n4wtt\hardware\tools\avr -prefs=runtime.tools.avrdude-6.3.0-arduino14.path=C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.15.0_x86__mdqgnx93n4wtt\hardware\tools\avr -prefs=runtime.tools.avr-gcc.path=C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.15.0_x86__mdqgnx93n4wtt\hardware\tools\avr -prefs=runtime.tools.avr-gcc-5.4.0-atmel3.6.1-arduino2.path=C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.15.0_x86__mdqgnx93n4wtt\hardware\tools\avr -prefs=runtime.tools.arduinoOTA.path=C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.15.0_x86__mdqgnx93n4wtt\hardware\tools\avr -prefs=runtime.tools.arduinoOTA-1.2.1.path=C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.15.0_x86__mdqgnx93n4wtt\hardware\tools\avr -verbose C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.15.0_x86__mdqgnx93n4wtt\examples\01.Basics\Blink\Blink.ino
Using board 'protrinket5' from platform in folder: G:\Users\Stefano\Documents\ArduinoData\packages\adafruit\hardware\avr\1.4.12
Using core 'arduino' from platform in folder: C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.15.0_x86__mdqgnx93n4wtt\hardware\arduino\avr
Detecting libraries used...
"C:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.15.0_x86__mdqgnx93n4wtt\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10807 -DARDUINO_AVR_PROTRINKET5 -DARDUINO_ARCH_AVR "-IC:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.15.0_x86__mdqgnx93n4wtt\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.15.0_x86__mdqgnx93n4wtt\\hardware\\arduino\\avr\\variants\\eightanaloginputs" "C:\\Users\\Stefano\\AppData\\Local\\Temp\\arduino_build_774576\\sketch\\Blink.ino.cpp" -o nul
Generating function prototypes...
"C:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.15.0_x86__mdqgnx93n4wtt\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10807 -DARDUINO_AVR_PROTRINKET5 -DARDUINO_ARCH_AVR "-IC:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.15.0_x86__mdqgnx93n4wtt\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.15.0_x86__mdqgnx93n4wtt\\hardware\\arduino\\avr\\variants\\eightanaloginputs" "C:\\Users\\Stefano\\AppData\\Local\\Temp\\arduino_build_774576\\sketch\\Blink.ino.cpp" -o "C:\\Users\\Stefano\\AppData\\Local\\Temp\\arduino_build_774576\\preproc\\ctags_target_for_gcc_minus_e.cpp"
"C:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.15.0_x86__mdqgnx93n4wtt\\tools-builder\\ctags\\5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\\Users\\Stefano\\AppData\\Local\\Temp\\arduino_build_774576\\preproc\\ctags_target_for_gcc_minus_e.cpp"
Compiling sketch...
"C:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.15.0_x86__mdqgnx93n4wtt\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10807 -DARDUINO_AVR_PROTRINKET5 -DARDUINO_ARCH_AVR "-IC:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.15.0_x86__mdqgnx93n4wtt\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.15.0_x86__mdqgnx93n4wtt\\hardware\\arduino\\avr\\variants\\eightanaloginputs" "C:\\Users\\Stefano\\AppData\\Local\\Temp\\arduino_build_774576\\sketch\\Blink.ino.cpp" -o "C:\\Users\\Stefano\\AppData\\Local\\Temp\\arduino_build_774576\\sketch\\Blink.ino.cpp.o"
Compiling libraries...
Compiling core...
"C:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.15.0_x86__mdqgnx93n4wtt\\hardware\\tools\\avr/bin/avr-gcc" -c -g -x assembler-with-cpp -flto -MMD -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10807 -DARDUINO_AVR_PROTRINKET5 -DARDUINO_ARCH_AVR "-IC:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.15.0_x86__mdqgnx93n4wtt\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.15.0_x86__mdqgnx93n4wtt\\hardware\\arduino\\avr\\variants\\eightanaloginputs" "C:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.15.0_x86__mdqgnx93n4wtt\\hardware\\arduino\\avr\\cores\\arduino\\wiring_pulse.S" -o "C:\\Users\\Stefano\\AppData\\Local\\Temp\\arduino_build_774576\\core\\wiring_pulse.S.o"
"C:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.15.0_x86__mdqgnx93n4wtt\\hardware\\tools\\avr/bin/avr-gcc" -c -g -Os -w -std=gnu11 -ffunction-sections -fdata-sections -MMD -flto -fno-fat-lto-objects -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10807 -DARDUINO_AVR_PROTRINKET5 -DARDUINO_ARCH_AVR "-IC:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.15.0_x86__mdqgnx93n4wtt\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.15.0_x86__mdqgnx93n4wtt\\hardware\\arduino\\avr\\variants\\eightanaloginputs" "C:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.15.0_x86__mdqgnx93n4wtt\\hardware\\arduino\\avr\\cores\\arduino\\hooks.c" -o "C:\\Users\\Stefano\\AppData\\Local\\Temp\\arduino_build_774576\\core\\hooks.c.o"
"C:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.15.0_x86__mdqgnx93n4wtt\\hardware\\tools\\avr/bin/avr-gcc" -c -g -Os -w -std=gnu11 -ffunction-sections -fdata-sections -MMD -flto -fno-fat-lto-objects -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10807 -DARDUINO_AVR_PROTRINKET5 -DARDUINO_ARCH_AVR "-IC:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.15.0_x86__mdqgnx93n4wtt\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.15.0_x86__mdqgnx93n4wtt\\hardware\\arduino\\avr\\variants\\eightanaloginputs" "C:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.15.0_x86__mdqgnx93n4wtt\\hardware\\arduino\\avr\\cores\\arduino\\wiring_shift.c" -o "C:\\Users\\Stefano\\AppData\\Local\\Temp\\arduino_build_774576\\core\\wiring_shift.c.o"
"C:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.15.0_x86__mdqgnx93n4wtt\\hardware\\tools\\avr/bin/avr-gcc" -c -g -Os -w -std=gnu11 -ffunction-sections -fdata-sections -MMD -flto -fno-fat-lto-objects -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10807 -DARDUINO_AVR_PROTRINKET5 -DARDUINO_ARCH_AVR "-IC:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.15.0_x86__mdqgnx93n4wtt\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.15.0_x86__mdqgnx93n4wtt\\hardware\\arduino\\avr\\variants\\eightanaloginputs" "C:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.15.0_x86__mdqgnx93n4wtt\\hardware\\arduino\\avr\\cores\\arduino\\wiring_pulse.c" -o "C:\\Users\\Stefano\\AppData\\Local\\Temp\\arduino_build_774576\\core\\wiring_pulse.c.o"
"C:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.15.0_x86__mdqgnx93n4wtt\\hardware\\tools\\avr/bin/avr-gcc" -c -g -Os -w -std=gnu11 -ffunction-sections -fdata-sections -MMD -flto -fno-fat-lto-objects -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10807 -DARDUINO_AVR_PROTRINKET5 -DARDUINO_ARCH_AVR "-IC:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.15.0_x86__mdqgnx93n4wtt\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.15.0_x86__mdqgnx93n4wtt\\hardware\\arduino\\avr\\variants\\eightanaloginputs" "C:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.15.0_x86__mdqgnx93n4wtt\\hardware\\arduino\\avr\\cores\\arduino\\wiring.c" -o "C:\\Users\\Stefano\\AppData\\Local\\Temp\\arduino_build_774576\\core\\wiring.c.o"
"C:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.15.0_x86__mdqgnx93n4wtt\\hardware\\tools\\avr/bin/avr-gcc" -c -g -Os -w -std=gnu11 -ffunction-sections -fdata-sections -MMD -flto -fno-fat-lto-objects -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10807 -DARDUINO_AVR_PROTRINKET5 -DARDUINO_ARCH_AVR "-IC:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.15.0_x86__mdqgnx93n4wtt\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.15.0_x86__mdqgnx93n4wtt\\hardware\\arduino\\avr\\variants\\eightanaloginputs" "C:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.15.0_x86__mdqgnx93n4wtt\\hardware\\arduino\\avr\\cores\\arduino\\wiring_analog.c" -o "C:\\Users\\Stefano\\AppData\\Local\\Temp\\arduino_build_774576\\core\\wiring_analog.c.o"
"C:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.15.0_x86__mdqgnx93n4wtt\\hardware\\tools\\avr/bin/avr-gcc" -c -g -Os -w -std=gnu11 -ffunction-sections -fdata-sections -MMD -flto -fno-fat-lto-objects -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10807 -DARDUINO_AVR_PROTRINKET5 -DARDUINO_ARCH_AVR "-IC:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.15.0_x86__mdqgnx93n4wtt\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.15.0_x86__mdqgnx93n4wtt\\hardware\\arduino\\avr\\variants\\eightanaloginputs" "C:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.15.0_x86__mdqgnx93n4wtt\\hardware\\arduino\\avr\\cores\\arduino\\wiring_digital.c" -o "C:\\Users\\Stefano\\AppData\\Local\\Temp\\arduino_build_774576\\core\\wiring_digital.c.o"
"C:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.15.0_x86__mdqgnx93n4wtt\\hardware\\tools\\avr/bin/avr-gcc" -c -g -Os -w -std=gnu11 -ffunction-sections -fdata-sections -MMD -flto -fno-fat-lto-objects -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10807 -DARDUINO_AVR_PROTRINKET5 -DARDUINO_ARCH_AVR "-IC:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.15.0_x86__mdqgnx93n4wtt\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.15.0_x86__mdqgnx93n4wtt\\hardware\\arduino\\avr\\variants\\eightanaloginputs" "C:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.15.0_x86__mdqgnx93n4wtt\\hardware\\arduino\\avr\\cores\\arduino\\WInterrupts.c" -o "C:\\Users\\Stefano\\AppData\\Local\\Temp\\arduino_build_774576\\core\\WInterrupts.c.o"
"C:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.15.0_x86__mdqgnx93n4wtt\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10807 -DARDUINO_AVR_PROTRINKET5 -DARDUINO_ARCH_AVR "-IC:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.15.0_x86__mdqgnx93n4wtt\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.15.0_x86__mdqgnx93n4wtt\\hardware\\arduino\\avr\\variants\\eightanaloginputs" "C:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.15.0_x86__mdqgnx93n4wtt\\hardware\\arduino\\avr\\cores\\arduino\\CDC.cpp" -o "C:\\Users\\Stefano\\AppData\\Local\\Temp\\arduino_build_774576\\core\\CDC.cpp.o"
"C:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.15.0_x86__mdqgnx93n4wtt\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10807 -DARDUINO_AVR_PROTRINKET5 -DARDUINO_ARCH_AVR "-IC:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.15.0_x86__mdqgnx93n4wtt\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.15.0_x86__mdqgnx93n4wtt\\hardware\\arduino\\avr\\variants\\eightanaloginputs" "C:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.15.0_x86__mdqgnx93n4wtt\\hardware\\arduino\\avr\\cores\\arduino\\abi.cpp" -o "C:\\Users\\Stefano\\AppData\\Local\\Temp\\arduino_build_774576\\core\\abi.cpp.o"
"C:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.15.0_x86__mdqgnx93n4wtt\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10807 -DARDUINO_AVR_PROTRINKET5 -DARDUINO_ARCH_AVR "-IC:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.15.0_x86__mdqgnx93n4wtt\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.15.0_x86__mdqgnx93n4wtt\\hardware\\arduino\\avr\\variants\\eightanaloginputs" "C:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.15.0_x86__mdqgnx93n4wtt\\hardware\\arduino\\avr\\cores\\arduino\\WMath.cpp" -o "C:\\Users\\Stefano\\AppData\\Local\\Temp\\arduino_build_774576\\core\\WMath.cpp.o"
"C:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.15.0_x86__mdqgnx93n4wtt\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10807 -DARDUINO_AVR_PROTRINKET5 -DARDUINO_ARCH_AVR "-IC:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.15.0_x86__mdqgnx93n4wtt\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.15.0_x86__mdqgnx93n4wtt\\hardware\\arduino\\avr\\variants\\eightanaloginputs" "C:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.15.0_x86__mdqgnx93n4wtt\\hardware\\arduino\\avr\\cores\\arduino\\Tone.cpp" -o "C:\\Users\\Stefano\\AppData\\Local\\Temp\\arduino_build_774576\\core\\Tone.cpp.o"
"C:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.15.0_x86__mdqgnx93n4wtt\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10807 -DARDUINO_AVR_PROTRINKET5 -DARDUINO_ARCH_AVR "-IC:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.15.0_x86__mdqgnx93n4wtt\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.15.0_x86__mdqgnx93n4wtt\\hardware\\arduino\\avr\\variants\\eightanaloginputs" "C:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.15.0_x86__mdqgnx93n4wtt\\hardware\\arduino\\avr\\cores\\arduino\\HardwareSerial2.cpp" -o "C:\\Users\\Stefano\\AppData\\Local\\Temp\\arduino_build_774576\\core\\HardwareSerial2.cpp.o"
"C:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.15.0_x86__mdqgnx93n4wtt\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10807 -DARDUINO_AVR_PROTRINKET5 -DARDUINO_ARCH_AVR "-IC:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.15.0_x86__mdqgnx93n4wtt\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.15.0_x86__mdqgnx93n4wtt\\hardware\\arduino\\avr\\variants\\eightanaloginputs" "C:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.15.0_x86__mdqgnx93n4wtt\\hardware\\arduino\\avr\\cores\\arduino\\WString.cpp" -o "C:\\Users\\Stefano\\AppData\\Local\\Temp\\arduino_build_774576\\core\\WString.cpp.o"
"C:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.15.0_x86__mdqgnx93n4wtt\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10807 -DARDUINO_AVR_PROTRINKET5 -DARDUINO_ARCH_AVR "-IC:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.15.0_x86__mdqgnx93n4wtt\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.15.0_x86__mdqgnx93n4wtt\\hardware\\arduino\\avr\\variants\\eightanaloginputs" "C:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.15.0_x86__mdqgnx93n4wtt\\hardware\\arduino\\avr\\cores\\arduino\\HardwareSerial0.cpp" -o "C:\\Users\\Stefano\\AppData\\Local\\Temp\\arduino_build_774576\\core\\HardwareSerial0.cpp.o"
"C:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.15.0_x86__mdqgnx93n4wtt\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10807 -DARDUINO_AVR_PROTRINKET5 -DARDUINO_ARCH_AVR "-IC:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.15.0_x86__mdqgnx93n4wtt\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.15.0_x86__mdqgnx93n4wtt\\hardware\\arduino\\avr\\variants\\eightanaloginputs" "C:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.15.0_x86__mdqgnx93n4wtt\\hardware\\arduino\\avr\\cores\\arduino\\IPAddress.cpp" -o "C:\\Users\\Stefano\\AppData\\Local\\Temp\\arduino_build_774576\\core\\IPAddress.cpp.o"
"C:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.15.0_x86__mdqgnx93n4wtt\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10807 -DARDUINO_AVR_PROTRINKET5 -DARDUINO_ARCH_AVR "-IC:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.15.0_x86__mdqgnx93n4wtt\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.15.0_x86__mdqgnx93n4wtt\\hardware\\arduino\\avr\\variants\\eightanaloginputs" "C:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.15.0_x86__mdqgnx93n4wtt\\hardware\\arduino\\avr\\cores\\arduino\\main.cpp" -o "C:\\Users\\Stefano\\AppData\\Local\\Temp\\arduino_build_774576\\core\\main.cpp.o"
"C:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.15.0_x86__mdqgnx93n4wtt\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10807 -DARDUINO_AVR_PROTRINKET5 -DARDUINO_ARCH_AVR "-IC:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.15.0_x86__mdqgnx93n4wtt\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.15.0_x86__mdqgnx93n4wtt\\hardware\\arduino\\avr\\variants\\eightanaloginputs" "C:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.15.0_x86__mdqgnx93n4wtt\\hardware\\arduino\\avr\\cores\\arduino\\USBCore.cpp" -o "C:\\Users\\Stefano\\AppData\\Local\\Temp\\arduino_build_774576\\core\\USBCore.cpp.o"
"C:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.15.0_x86__mdqgnx93n4wtt\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10807 -DARDUINO_AVR_PROTRINKET5 -DARDUINO_ARCH_AVR "-IC:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.15.0_x86__mdqgnx93n4wtt\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.15.0_x86__mdqgnx93n4wtt\\hardware\\arduino\\avr\\variants\\eightanaloginputs" "C:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.15.0_x86__mdqgnx93n4wtt\\hardware\\arduino\\avr\\cores\\arduino\\new.cpp" -o "C:\\Users\\Stefano\\AppData\\Local\\Temp\\arduino_build_774576\\core\\new.cpp.o"
"C:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.15.0_x86__mdqgnx93n4wtt\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10807 -DARDUINO_AVR_PROTRINKET5 -DARDUINO_ARCH_AVR "-IC:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.15.0_x86__mdqgnx93n4wtt\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.15.0_x86__mdqgnx93n4wtt\\hardware\\arduino\\avr\\variants\\eightanaloginputs" "C:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.15.0_x86__mdqgnx93n4wtt\\hardware\\arduino\\avr\\cores\\arduino\\HardwareSerial3.cpp" -o "C:\\Users\\Stefano\\AppData\\Local\\Temp\\arduino_build_774576\\core\\HardwareSerial3.cpp.o"
"C:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.15.0_x86__mdqgnx93n4wtt\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10807 -DARDUINO_AVR_PROTRINKET5 -DARDUINO_ARCH_AVR "-IC:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.15.0_x86__mdqgnx93n4wtt\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.15.0_x86__mdqgnx93n4wtt\\hardware\\arduino\\avr\\variants\\eightanaloginputs" "C:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.15.0_x86__mdqgnx93n4wtt\\hardware\\arduino\\avr\\cores\\arduino\\HardwareSerial.cpp" -o "C:\\Users\\Stefano\\AppData\\Local\\Temp\\arduino_build_774576\\core\\HardwareSerial.cpp.o"
"C:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.15.0_x86__mdqgnx93n4wtt\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10807 -DARDUINO_AVR_PROTRINKET5 -DARDUINO_ARCH_AVR "-IC:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.15.0_x86__mdqgnx93n4wtt\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.15.0_x86__mdqgnx93n4wtt\\hardware\\arduino\\avr\\variants\\eightanaloginputs" "C:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.15.0_x86__mdqgnx93n4wtt\\hardware\\arduino\\avr\\cores\\arduino\\PluggableUSB.cpp" -o "C:\\Users\\Stefano\\AppData\\Local\\Temp\\arduino_build_774576\\core\\PluggableUSB.cpp.o"
"C:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.15.0_x86__mdqgnx93n4wtt\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10807 -DARDUINO_AVR_PROTRINKET5 -DARDUINO_ARCH_AVR "-IC:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.15.0_x86__mdqgnx93n4wtt\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.15.0_x86__mdqgnx93n4wtt\\hardware\\arduino\\avr\\variants\\eightanaloginputs" "C:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.15.0_x86__mdqgnx93n4wtt\\hardware\\arduino\\avr\\cores\\arduino\\Print.cpp" -o "C:\\Users\\Stefano\\AppData\\Local\\Temp\\arduino_build_774576\\core\\Print.cpp.o"
"C:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.15.0_x86__mdqgnx93n4wtt\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10807 -DARDUINO_AVR_PROTRINKET5 -DARDUINO_ARCH_AVR "-IC:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.15.0_x86__mdqgnx93n4wtt\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.15.0_x86__mdqgnx93n4wtt\\hardware\\arduino\\avr\\variants\\eightanaloginputs" "C:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.15.0_x86__mdqgnx93n4wtt\\hardware\\arduino\\avr\\cores\\arduino\\HardwareSerial1.cpp" -o "C:\\Users\\Stefano\\AppData\\Local\\Temp\\arduino_build_774576\\core\\HardwareSerial1.cpp.o"
"C:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.15.0_x86__mdqgnx93n4wtt\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10807 -DARDUINO_AVR_PROTRINKET5 -DARDUINO_ARCH_AVR "-IC:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.15.0_x86__mdqgnx93n4wtt\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.15.0_x86__mdqgnx93n4wtt\\hardware\\arduino\\avr\\variants\\eightanaloginputs" "C:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.15.0_x86__mdqgnx93n4wtt\\hardware\\arduino\\avr\\cores\\arduino\\Stream.cpp" -o "C:\\Users\\Stefano\\AppData\\Local\\Temp\\arduino_build_774576\\core\\Stream.cpp.o"
"C:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.15.0_x86__mdqgnx93n4wtt\\hardware\\tools\\avr/bin/avr-gcc-ar" rcs "C:\\Users\\Stefano\\AppData\\Local\\Temp\\arduino_build_774576\\core\\core.a" "C:\\Users\\Stefano\\AppData\\Local\\Temp\\arduino_build_774576\\core\\CDC.cpp.o"
"C:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.15.0_x86__mdqgnx93n4wtt\\hardware\\tools\\avr/bin/avr-gcc-ar" rcs "C:\\Users\\Stefano\\AppData\\Local\\Temp\\arduino_build_774576\\core\\core.a" "C:\\Users\\Stefano\\AppData\\Local\\Temp\\arduino_build_774576\\core\\HardwareSerial.cpp.o"
"C:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.15.0_x86__mdqgnx93n4wtt\\hardware\\tools\\avr/bin/avr-gcc-ar" rcs "C:\\Users\\Stefano\\AppData\\Local\\Temp\\arduino_build_774576\\core\\core.a" "C:\\Users\\Stefano\\AppData\\Local\\Temp\\arduino_build_774576\\core\\HardwareSerial0.cpp.o"
"C:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.15.0_x86__mdqgnx93n4wtt\\hardware\\tools\\avr/bin/avr-gcc-ar" rcs "C:\\Users\\Stefano\\AppData\\Local\\Temp\\arduino_build_774576\\core\\core.a" "C:\\Users\\Stefano\\AppData\\Local\\Temp\\arduino_build_774576\\core\\HardwareSerial1.cpp.o"
"C:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.15.0_x86__mdqgnx93n4wtt\\hardware\\tools\\avr/bin/avr-gcc-ar" rcs "C:\\Users\\Stefano\\AppData\\Local\\Temp\\arduino_build_774576\\core\\core.a" "C:\\Users\\Stefano\\AppData\\Local\\Temp\\arduino_build_774576\\core\\HardwareSerial2.cpp.o"
"C:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.15.0_x86__mdqgnx93n4wtt\\hardware\\tools\\avr/bin/avr-gcc-ar" rcs "C:\\Users\\Stefano\\AppData\\Local\\Temp\\arduino_build_774576\\core\\core.a" "C:\\Users\\Stefano\\AppData\\Local\\Temp\\arduino_build_774576\\core\\HardwareSerial3.cpp.o"
"C:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.15.0_x86__mdqgnx93n4wtt\\hardware\\tools\\avr/bin/avr-gcc-ar" rcs "C:\\Users\\Stefano\\AppData\\Local\\Temp\\arduino_build_774576\\core\\core.a" "C:\\Users\\Stefano\\AppData\\Local\\Temp\\arduino_build_774576\\core\\IPAddress.cpp.o"
"C:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.15.0_x86__mdqgnx93n4wtt\\hardware\\tools\\avr/bin/avr-gcc-ar" rcs "C:\\Users\\Stefano\\AppData\\Local\\Temp\\arduino_build_774576\\core\\core.a" "C:\\Users\\Stefano\\AppData\\Local\\Temp\\arduino_build_774576\\core\\PluggableUSB.cpp.o"
"C:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.15.0_x86__mdqgnx93n4wtt\\hardware\\tools\\avr/bin/avr-gcc-ar" rcs "C:\\Users\\Stefano\\AppData\\Local\\Temp\\arduino_build_774576\\core\\core.a" "C:\\Users\\Stefano\\AppData\\Local\\Temp\\arduino_build_774576\\core\\Print.cpp.o"
"C:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.15.0_x86__mdqgnx93n4wtt\\hardware\\tools\\avr/bin/avr-gcc-ar" rcs "C:\\Users\\Stefano\\AppData\\Local\\Temp\\arduino_build_774576\\core\\core.a" "C:\\Users\\Stefano\\AppData\\Local\\Temp\\arduino_build_774576\\core\\Stream.cpp.o"
"C:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.15.0_x86__mdqgnx93n4wtt\\hardware\\tools\\avr/bin/avr-gcc-ar" rcs "C:\\Users\\Stefano\\AppData\\Local\\Temp\\arduino_build_774576\\core\\core.a" "C:\\Users\\Stefano\\AppData\\Local\\Temp\\arduino_build_774576\\core\\Tone.cpp.o"
"C:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.15.0_x86__mdqgnx93n4wtt\\hardware\\tools\\avr/bin/avr-gcc-ar" rcs "C:\\Users\\Stefano\\AppData\\Local\\Temp\\arduino_build_774576\\core\\core.a" "C:\\Users\\Stefano\\AppData\\Local\\Temp\\arduino_build_774576\\core\\USBCore.cpp.o"
"C:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.15.0_x86__mdqgnx93n4wtt\\hardware\\tools\\avr/bin/avr-gcc-ar" rcs "C:\\Users\\Stefano\\AppData\\Local\\Temp\\arduino_build_774576\\core\\core.a" "C:\\Users\\Stefano\\AppData\\Local\\Temp\\arduino_build_774576\\core\\WInterrupts.c.o"
"C:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.15.0_x86__mdqgnx93n4wtt\\hardware\\tools\\avr/bin/avr-gcc-ar" rcs "C:\\Users\\Stefano\\AppData\\Local\\Temp\\arduino_build_774576\\core\\core.a" "C:\\Users\\Stefano\\AppData\\Local\\Temp\\arduino_build_774576\\core\\WMath.cpp.o"
"C:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.15.0_x86__mdqgnx93n4wtt\\hardware\\tools\\avr/bin/avr-gcc-ar" rcs "C:\\Users\\Stefano\\AppData\\Local\\Temp\\arduino_build_774576\\core\\core.a" "C:\\Users\\Stefano\\AppData\\Local\\Temp\\arduino_build_774576\\core\\WString.cpp.o"
"C:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.15.0_x86__mdqgnx93n4wtt\\hardware\\tools\\avr/bin/avr-gcc-ar" rcs "C:\\Users\\Stefano\\AppData\\Local\\Temp\\arduino_build_774576\\core\\core.a" "C:\\Users\\Stefano\\AppData\\Local\\Temp\\arduino_build_774576\\core\\abi.cpp.o"
"C:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.15.0_x86__mdqgnx93n4wtt\\hardware\\tools\\avr/bin/avr-gcc-ar" rcs "C:\\Users\\Stefano\\AppData\\Local\\Temp\\arduino_build_774576\\core\\core.a" "C:\\Users\\Stefano\\AppData\\Local\\Temp\\arduino_build_774576\\core\\hooks.c.o"
"C:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.15.0_x86__mdqgnx93n4wtt\\hardware\\tools\\avr/bin/avr-gcc-ar" rcs "C:\\Users\\Stefano\\AppData\\Local\\Temp\\arduino_build_774576\\core\\core.a" "C:\\Users\\Stefano\\AppData\\Local\\Temp\\arduino_build_774576\\core\\main.cpp.o"
"C:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.15.0_x86__mdqgnx93n4wtt\\hardware\\tools\\avr/bin/avr-gcc-ar" rcs "C:\\Users\\Stefano\\AppData\\Local\\Temp\\arduino_build_774576\\core\\core.a" "C:\\Users\\Stefano\\AppData\\Local\\Temp\\arduino_build_774576\\core\\new.cpp.o"
"C:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.15.0_x86__mdqgnx93n4wtt\\hardware\\tools\\avr/bin/avr-gcc-ar" rcs "C:\\Users\\Stefano\\AppData\\Local\\Temp\\arduino_build_774576\\core\\core.a" "C:\\Users\\Stefano\\AppData\\Local\\Temp\\arduino_build_774576\\core\\wiring.c.o"
"C:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.15.0_x86__mdqgnx93n4wtt\\hardware\\tools\\avr/bin/avr-gcc-ar" rcs "C:\\Users\\Stefano\\AppData\\Local\\Temp\\arduino_build_774576\\core\\core.a" "C:\\Users\\Stefano\\AppData\\Local\\Temp\\arduino_build_774576\\core\\wiring_analog.c.o"
"C:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.15.0_x86__mdqgnx93n4wtt\\hardware\\tools\\avr/bin/avr-gcc-ar" rcs "C:\\Users\\Stefano\\AppData\\Local\\Temp\\arduino_build_774576\\core\\core.a" "C:\\Users\\Stefano\\AppData\\Local\\Temp\\arduino_build_774576\\core\\wiring_digital.c.o"
"C:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.15.0_x86__mdqgnx93n4wtt\\hardware\\tools\\avr/bin/avr-gcc-ar" rcs "C:\\Users\\Stefano\\AppData\\Local\\Temp\\arduino_build_774576\\core\\core.a" "C:\\Users\\Stefano\\AppData\\Local\\Temp\\arduino_build_774576\\core\\wiring_pulse.S.o"
"C:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.15.0_x86__mdqgnx93n4wtt\\hardware\\tools\\avr/bin/avr-gcc-ar" rcs "C:\\Users\\Stefano\\AppData\\Local\\Temp\\arduino_build_774576\\core\\core.a" "C:\\Users\\Stefano\\AppData\\Local\\Temp\\arduino_build_774576\\core\\wiring_pulse.c.o"
"C:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.15.0_x86__mdqgnx93n4wtt\\hardware\\tools\\avr/bin/avr-gcc-ar" rcs "C:\\Users\\Stefano\\AppData\\Local\\Temp\\arduino_build_774576\\core\\core.a" "C:\\Users\\Stefano\\AppData\\Local\\Temp\\arduino_build_774576\\core\\wiring_shift.c.o"
Archiving built core (caching) in: C:\Users\Stefano\AppData\Local\Temp\arduino_cache_655027\core\core_adafruit_avr_protrinket5_83dd9225a3a2a4e5654b35f3e742d65a.a
Linking everything together...
"C:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.15.0_x86__mdqgnx93n4wtt\\hardware\\tools\\avr/bin/avr-gcc" -w -Os -g -flto -fuse-linker-plugin -Wl,--gc-sections -mmcu=atmega328p -o "C:\\Users\\Stefano\\AppData\\Local\\Temp\\arduino_build_774576/Blink.ino.elf" "C:\\Users\\Stefano\\AppData\\Local\\Temp\\arduino_build_774576\\sketch\\Blink.ino.cpp.o" "C:\\Users\\Stefano\\AppData\\Local\\Temp\\arduino_build_774576/core\\core.a" "-LC:\\Users\\Stefano\\AppData\\Local\\Temp\\arduino_build_774576" -lm
"C:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.15.0_x86__mdqgnx93n4wtt\\hardware\\tools\\avr/bin/avr-objcopy" -O ihex -j .eeprom --set-section-flags=.eeprom=alloc,load --no-change-warnings --change-section-lma .eeprom=0 "C:\\Users\\Stefano\\AppData\\Local\\Temp\\arduino_build_774576/Blink.ino.elf" "C:\\Users\\Stefano\\AppData\\Local\\Temp\\arduino_build_774576/Blink.ino.eep"
"C:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.15.0_x86__mdqgnx93n4wtt\\hardware\\tools\\avr/bin/avr-objcopy" -O ihex -R .eeprom "C:\\Users\\Stefano\\AppData\\Local\\Temp\\arduino_build_774576/Blink.ino.elf" "C:\\Users\\Stefano\\AppData\\Local\\Temp\\arduino_build_774576/Blink.ino.hex"
"C:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.15.0_x86__mdqgnx93n4wtt\\hardware\\tools\\avr/bin/avr-size" -A "C:\\Users\\Stefano\\AppData\\Local\\Temp\\arduino_build_774576/Blink.ino.elf"
Sketch uses 930 bytes (3%) of program storage space. Maximum is 28672 bytes.
Global variables use 9 bytes of dynamic memory.
Please select a Port before Upload
- Zarek85
I've followed all the tutorial, but the error is the same :/
"Select a Port before Upload" :(
- Zarek85
No one can help me? :(
Are you using an FTDI cable or USB?
Have you selected a port in the Tools menu?
Have you tried using a different cable and/or USB port?
If you are using a USB 3.0 port, try a USB 2.0 port.
- Zarek85
I use an USB cable
In the port menu I can't select any port, the port selection is grey.
I've tried lot of usb port and cable, and another pc with windows 7.
I've also used an hub with usb 2.0
Everything works, driver are installed ecc. But when I try to upload I get the error "Select a Port"
Make sure that you have "Pro Trinket 5v/16MHz (USB)" selected as the board type.I use an USB cable
"Pro Trinket 5v/16MHz (FTDI)" requires an FTDI cable.
- Zarek85
Yes, it is selected as board, but still the same error :/
- Zarek85
Today I will try with a Macbook, so I can say if it is a Windows Problem :/
- adafruit2
Try 1.8.6 - theres a bug in 1.8.7 that Arduino knows about but hasn't fixed yet :(
https://github.com/arduino/Arduino/issues/8052
- Zarek85
Hello!
On Mac everything goes well, I've just selected a random port and it works fine.
On Windows the port selection is grey and I don't know how to unlock it.
Today I will try to use an older version of Arduino IDE on Windows, so I can check it and I will write here ^_^
