Trinket M0 dotstar always on
by JOTS on Sun Jan 13, 2019 5:37 pm
I just starting using a trinket for the first time. I am using maker.makecode.com.
I can blink D13, use a button to turn it on and off, etc. For any of my scripts the onboard dotstar is always on a pink/purple color. If I try and set it to different colors it doesn't affect it, if I try to set the brightness to 0 it doesn't affect it. Am I missing something basic, or do I have a defective unit?
This is an example of my extremely simple test, that results in the pixel always being on (which happens for any script)
input.buttonD1.onEvent(ButtonEvent.Down, function () {
pins.D13.digitalWrite(true)
input.buttonD1.onEvent(ButtonEvent.Up, function () {
pins.D13.digitalWrite(false)
forever(function () {
pixel.setColor(0x000000)
pixel.setBrightness(0)
JOTS
Re: Trinket M0 dotstar always on
by PeteH51 on Sun Jan 13, 2019 9:28 pm
What is your code file named? It should be code.txt or .py OR main.txt or .py those are the filenames the sw looks to run.
You may have to manually rename them.
PeteH51
by JOTS on Mon Jan 14, 2019 10:31 am
Thanks Pete, but I am not using python. I'm trying to usethe generated .uf2 files downloaded from maker.makecode.com. The odd thing is D13 works, so I think my code is running,, just that the dotstar is acting in an unexpected way.
thanks,
Jon
JOTS
by adafruit_support_carter on Tue Jan 15, 2019 4:15 pm
maker.makecode.com is beta. Some functionality may not be supported yet.
by JOTS on Thu Jan 17, 2019 5:27 pm
Can you confirm that this is known/expected behavior at this point? I want to confirm that my board is not defective.
Thanks,
Jon
JOTS
by adafruit_support_carter on Thu Jan 17, 2019 5:54 pm
Not really, since I don't know what it's actually doing codewise.
If you double press reset so that you see the TRINKETBOOT folder, the DotStar should be green and the little red LED next to the micro USB connector should be on.
Another idea would be to use CircuitPython, then we can control it directly.
by garyhlucas on Wed Jan 30, 2019 10:05 am
I have 3 trinket M0 and can confirm that they all have the dotstar showing a purple color all the time. I want to use the onboard dotstar to show the color that a color sensor uses and trying to find the code to drive that dotstar.
garyhlucas
by adafruit_support_carter on Wed Jan 30, 2019 1:38 pm
It is probably not supported in maker.makecode.com at this time.
It is supported in Arduino and CircuitPython.
