Pin03 and Pin04 differ?
by muellermario on Sat Jan 19, 2019 11:18 am
I want to use the trinket 5V for a HID. I connected 5 buttons to Pins 0 - 4
0,1,2 work correct
3 & 4 show a strange behaviour. Is there any difference with PIN 3 and 4 ?
Regards
Mario
muellermario
Re: Pin03 and Pin04 differ?
by millercommamatt on Sat Jan 19, 2019 11:54 am
millercommamatt
by muellermario on Sat Jan 19, 2019 12:01 pm
Hi millercommamatt,
many thanks for your reply. I am a newby and not very familiar with terms like SPI and I2C.
Does that mean Pin03 and Pin04 can not be used to read a buttons state?
Regards
Mario
muellermario
by PeteH51 on Sun Jan 20, 2019 12:25 am
My understanding is that pins 3 and 4 are used by the USB initially. If you want to use them in your code, you should DL the code, and then remove the USB connection, powering the trinket from a battery.
See https://learn.adafruit.com/tap-tempo-tr ... gs-learned
PeteH51
by adafruit_support_carter on Mon Jan 21, 2019 4:10 pm
First, we'd recommend switching to this:
https://www.adafruit.com/product/3500
since the original Trinket is being deprecated.
On the older Trinket, pins were very sparse and served multiple functions. Pins 3 and 4 are attached to the USB data lines. There are some associated resistors that can cause interference for attached hardware. See schematic:
https://learn.adafruit.com/introducing- ... atics-11-4
From the pinout page, for GPIO 3 and 4:
The best use of these pins is as outputs to things like LEDs.
There's also an LED attached to GPIO1.
