LiPo backpack
LiPo backpack
by redruff on Thu Jan 24, 2019 8:47 pm
Will the LiPo backpack work in the Trinket MO?
redruff
Re: LiPo backpack
by adafruit_support_carter on Thu Jan 24, 2019 9:07 pm
Re: LiPo backpack
by redruff on Thu Jan 24, 2019 9:35 pm
adafruit_support_carter wrote:Do you mean this?
https://www.adafruit.com/product/2124
Yes, that's the one.
redruff
Re: LiPo backpack
by adafruit_support_carter on Fri Jan 25, 2019 1:40 pm
It won't work piggyback style since the pin footprint is different on the Trinket M0. But if you wired the pins up as below, it should work.
backpack - trinket M0
BAT - Bat
GND - Gnd
5V - USB
Re: LiPo backpack
by redruff on Fri Jan 25, 2019 5:21 pm
adafruit_support_carter wrote:It won't work piggyback style since the pin footprint is different on the Trinket M0. But if you wired the pins up as below, it should work.
BAT - Bat
GND - Gnd
5V - USB
Thank you.
I was reading some reviews online and a couple people said if you don't use Adafruit batteries the polarity is reversed?
redruff
Re: LiPo backpack
by adafruit_support_carter on Mon Jan 28, 2019 12:45 pm
Our batteries will work with our products. We make sure all the polarities and connectors are the same through out the products.
There is no standard for polarity. Other batteries may be different.
Re: LiPo backpack
by redruff on Tue Mar 12, 2019 5:22 pm
Finally got back to this:
Hooked
grd to grd
batt to batt
5v to USB
SMOKED IT!
Dooh
redruff
Re: LiPo backpack
by XRAD on Tue Mar 12, 2019 10:26 pm
Too bad! How did that happen? reverse polarity? Another brand battery?
XRAD
Re: LiPo backpack
by redruff on Wed Mar 13, 2019 10:55 am
XRAD wrote:Too bad! How did that happen? reverse polarity? Another brand battery?
I did not use an Adafruit battery.
I used an off brand battery and hooked + to + and - to -.
POOF!
redruff
Re: LiPo backpack
by adafruit_support_mike on Thu Mar 14, 2019 4:07 am
It sounds like you got a LiPo whose JST-PH2 connector was wired with the opposite polarity from the version we use.
There are two ways to arrange the red and black wires in the plastic housing, and you can find both versions in the wild. The version we use puts the red/positive wire on the side closest to where it says 'Lipoly' on the PCB, and the negative/black wire closest to the mounting hole.
Connecting a LiPo with the wires swapped can kill the LiPo charging chip.
Re: LiPo backpack
by redruff on Thu Mar 14, 2019 6:24 am
adafruit_support_mike wrote:It sounds like you got a LiPo whose JST-PH2 connector was wired with the opposite polarity from the version we use.
That's my guess as well.
But on the bright side, for my design I think I will forgo the backpack and make the battery accessible so it can be pulled out of the case and charged with a USB 1s charger.
Will simplify things a bit.
But just for curiosity, I have another one and I'm going to try it with the polarity swapped.
redruff
Re: LiPo backpack
by Khouji123 on Thu Mar 14, 2019 9:17 pm
Did you get another battery?
Khouji123
