Q. about Neopixel Classes
by Blueshark on Sat Jan 26, 2019 8:15 pm
While looking for Neopixel code I've noticed that there are Two types of calls for Neopixels…..
What is the diffirence between pixel.XXXXX and strip.XXXXX
see code examples of what I'm talking about... same Function written in different ways....
   void rainbowCycle(uint8_t wait)
  uint16_t i, j;
  for (j = 0; j < 256 * 5; j++)
  { // 5 cycles of all colors on wheel
    for (i = 0; i < strip.numPixels(); i++)
      strip.setPixelColor(i, Wheel(((i * 256 / strip.numPixels()) + j) & 255));
    strip.show();
    delay(wait);
    void rainbowCycle(uint8_t wait) {
  uint16_t i, j;
  for(j=0; j<256*5; j++) { // 5 cycles of all colors on wheel
    for(i=0; i< pixel.numPixels(); i++) {
      pixel.setPixelColor(i, Wheel(((i * 256 / pixel.numPixels()) + j) & 255));
    pixel.show();
    delay(wait);
Whats the difference between pixel.... and strip....
Cheers
Blueshark
Re: Q. about Neopixel Classes
by kcl1s on Sat Jan 26, 2019 9:35 pm
When you declare a Neopixel object you give it a name. The strandtest example uses this
Adafruit_NeoPixel strip = Adafruit_NeoPixel(60, PIN, NEO_GRB + NEO_KHZ800);
where strip is the name. It could be declared as pixel, lights, dodad or any other name you chose. Then you just use that name for your code as in dodad.show();
You can use different names and have Neopixels objects on more than one pin.
Adafruit_NeoPixel strip2 = Adafruit_NeoPixel(60, PIN2, NEO_GRB + NEO_KHZ800);
Hope this helps
Fellow hobbyist
Keith
kcl1s
by Blueshark on Sat Jan 26, 2019 10:24 pm
Thank You Keith, for the explanation...
This clears things up...
Blueshark
