Trinket M0 Timers
Trinket M0 Timers
by eboxhead on Mon Jan 28, 2019 5:17 pm
I'm looking to adjust the PWM frequency on the Trinket M0, but I'm a little lost on where to find what timers do what on this device. Looking through the SAMD21 datasheet it the port mappings don't appear to call out a timer for PA06 and PA07 (pins 3 and 4). I'm sure I'm looking in the wrong place... are there any suggestions on where else I might be able to find out what timers the Trinket M0 (and the SAMD for that matter) uses for what?
eboxhead
Re: Trinket M0 Timers
by adafruit_support_mike on Tue Jan 29, 2019 4:22 am
The best (though not obvious) place to start looking for information about the configuration of a specific board is the 'variant.cpp' file in the board support package:
https://github.com/adafruit/ArduinoCore ... ariant.cpp
That includes an array of flags that describe what each pin can do. Functions like analogWrite() check the array to decide how to handle a given pin.
From a quick skim, it looks like most of the PWM pins are connected to TCC0 and TCC1.
The SAMD21 has two kinds of PWM peripherals: the Timer-Counter which can generate two signals in a few basic patterns, and the Timer-Counter-for-Control which can generate more kinds of patterns on up to 8 pins.
To change the PWM frequency you'll want to look at its Generic Clock source and the prescaler value applied by the TCC's counter.
by eboxhead on Wed Jan 30, 2019 1:04 pm
Awesome, thank you!
I'll give that a look in a bit.
eboxhead
