Q. Can Trinket M0 use a SPI Bluetooth
by Blueshark on Thu Jan 31, 2019 5:59 pm
I'm trying to connect an SPI Bluetooth (see link) to a Trinket M0....
https://www.adafruit.com/product/2633
The Trinket M0
Digital #2 is Hardware MISO
Digital #3 is Hardware SCK
Digital #4 is Hardware MOSI
This leaves me with 2 Digital pins to use on my project which is fine.... but what about the other pins on the SPI Bluefruit Bluetooth... CS, IRQ, and RST... are those pins just left out and the SPI Bluefruit Bluetooth Module will work?
Cheers
Blueshark
Re: Q. Can Trinket M0 use a SPI Bluetooth
by adafruit_support_carter on Thu Jan 31, 2019 6:23 pm
The RST pin is optional:
https://learn.adafruit.com/introducing- ... pinout-4-2
so you might be able to just get it to work using your 2 remaining pins for CS and IRQ. But the driver would need to support that. For example, the current version of the CircuitPython driver requires it:
https://github.com/adafruit/Adafruit_Ci ... est.py#L10
and for Arduino you would have to use hardware SPI:
https://github.com/adafruit/Adafruit_Bl ... _SPI.h#L90
So, it *might* be possible, but pretty tight.
