Voltage in for MO
Voltage in for MO
by Prwall on Fri Feb 01, 2019 2:31 pm
Hi, newbie here.
What’s the max voltage into the BAT pin on the Trinket MO? I suspect it’s just as it states in the board, 6V.
Trying to run with a 12v battery, what’s the easiest/smallest way to power the MO with this battery?
Thanks.
Prwall
Re: Voltage in for MO
by franklin97355 on Fri Feb 01, 2019 4:08 pm
Depending on what else you plan to run from the Trinket you could use a resistor voltage divider or a small voltage regulator that can handle the 12-volt input.
franklin97355
by Prwall on Fri Feb 01, 2019 4:24 pm
Thanks for your reply.
It won’t be running much, just triggering the electronic speed control for an EDF motor.
Prwall
by languer on Sat Feb 02, 2019 3:38 am
A small regulator (https://www.adafruit.com/product/2236) is best. A Zener diode (e.g.) with series resistor would be second best. I would not go the resistive divider way.
languer
by Prwall on Fri Feb 08, 2019 10:14 pm
Thanks for the help. Found a small converter prewired that will take in up to 24v in and put out 5v at 3a.
Prwall
