error in <ProTrinketKeyboard.h>
by muellermario on Sat Feb 02, 2019 5:33 am
could anybody please doulecheck (I am using ProTrinket 5 V)?
When I use:
TrinketKeyboard.pressKey(KEYCODE_MOD_LEFT_SHIFT, KEYCODE_MOD_RIGHT_SHIFT, MODIFIER_NONE);
the sign § gets send!!! (As I got a german keyboard it could be that you see a different sign)
As I need the above coding statement for a pinball, I would be glad if you could check!
Regards
Mario
muellermario
Re: error in <ProTrinketKeyboard.h>
by adafruit_support_mike on Sun Feb 03, 2019 4:19 am
The values you're sending don't make sense.
KEYCODE_MOD_LEFT_SHIFT and KEYCODE_MOD_RIGHT_SHIFT are modifiers that get encoded in the first byte of a HID packet. MODIFIER_NONE contradicts the other two.
The function above also sends KEYCODE_MOD_RIGHT_SHIFT and MODIFIER_NONE as keypresses rather than modifiers.
The expression:
creates a HID packet that says, "press the left shift key and the key with code 0x20". 0x20 happens to be the HID key code for '3', so the packet means "shift-3". That matches the § symbol on a German keyboard.
If you want to use the left and right shift keys as modifers, do it like this:
    TrinketKeyboard.pressKey( KEYCODE_MOD_LEFT_SHIFT + KEYCODE_MOD_RIGHT_SHIFT, KEYCODE_SPACE );
or whatever keypress you want the shift keys to modify.
If you want to use the left and right shift keys as keypresses by themselves, do this:
    TrinketKeyboard.pressKey( 0, KEYCODE_LEFT_SHIFT, KEYCODE_RIGHT_SHIFT );
by muellermario on Sun Feb 03, 2019 7:07 am
Hi Mike,
many many thanks!
Regards
Mario
muellermario
