Servo example error
Servo example error
by WTS on Thu Feb 07, 2019 8:50 pm
I am going through the servo example found in
http://descargas.cetronic.es/ADAFRUITTRINKETM0.pdf
I downloaded and put the simpleio.mpy file into the CIRCUITPY/lib folder on the trinket M0.
Now I get this error:
File "code.py", line 6, in <module>
AttributeError: 'module' object has no attribute 'Servo'
Can anyone help?
-------------------------------------------------------- CODE --------------------------------------------------------------------
import time
import board
import simpleio
# For the M0 boards:
servo1 = simpleio.Servo(board.A2)
while True:
for angle in range(0, 180, 5): # 0-180 degrees, 5 degrees at a time
servo1.angle = angle
time.sleep(0.05)
for angle in range(180, 0, -5): # 180-0 degrees, 5 degrees at a time
time.sleep(0.05)
WTS
Re: Servo example error
by oesterle on Thu Feb 07, 2019 9:04 pm
Hi, WTS!
According to a recent discussion here on the forums (Trinket M0 Servo Control Failure), simpleio.Servo has been replaced with adafruit_motor.Servo.
Your PDF is a snapshot from June 2018; I'd suggest using the online version which is more current: CircuitPython Servo | Adafruit Trinket M0 | Adafruit Learning System.
Cheers,
Eric
oesterle
