Trinket M0 arrived dead?
by duh102 on Sun Feb 10, 2019 1:00 pm
Hey all!
I ordered three Trinket M0s around a week ago and two of them function perfectly fine, I was able to both use circuitpython and then upload directly using arduino. The third one, however, doesn't seem to be working and I'm not sure if it's something I did or if it was DOA.
The symptoms are that once plugged in, the neopixel flashes blue for a split second then turns off, while the green power LED lights constantly. Clicking the button does nothing, nor does double pressing it to get into bootloader mode like I can on the other two. As far as I can tell, the traces all look fine. Unfortunately I did not test it before soldering up the pins, I tested one of the others and then soldered all of them up in one go.
Thanks for any help!
duh102
Re: Trinket M0 arrived dead?
by adafruit_support_carter on Sun Feb 10, 2019 3:21 pm
Can you post a photo of the problematic board so we can see if it might be related to the soldering.
by duh102 on Sun Feb 10, 2019 9:11 pm
Sure thing!
The problem board is on the right in this picture, a working board on the left, both from the same order
Here's a slightly more zoomed in version.
duh102
by adafruit_support_carter on Mon Feb 11, 2019 1:13 pm
Thanks. I don't see anything with that soldering that could explain the behavior. It's might just be an oddball board. Let's replace it.
Send an email to support@adafruit.com with a link to this thread and your order number and they can send you a new Trinket M0.
by C_Mann on Thu Mar 14, 2019 6:57 pm
I have exactly the same problem, except i purchased mine on Amazon. I was hoping for a fix.
Lesson learned I suppose.
C_Mann
by adafruit_support_carter on Thu Mar 14, 2019 7:06 pm
@C_Mann Please start a new thread for your issue.
