Modules / functions for CircuitPython
by drtomsutherland on Mon Feb 11, 2019 10:03 am
How do I find current listing for Modules/functions/Modes/etc... fro CircuitPyhton? I have been following the examples and they lead you down a path telling you how to do a specific thing, like sending a pwm to a servo. The example below says you create an servo and write your angle to servo.angle. How do I know what properties are available in servo. ? servo.angle is just one, are their others? Same goes for pulseio.XXX
example from: https://learn.adafruit.com/using-servos ... cuitpython
import time
import board
import pulseio
import adafruit_motor.servo
# Initialize PWM output for the servo (on pin D5) and servo:
pwm = pulseio.PWMOut(board.D5, frequency=50)
servo = adafruit_motor.servo.Servo(pwm)
servo.angle = 0
drtomsutherland
Re: Modules / functions for CircuitPython
by millercommamatt on Mon Feb 11, 2019 1:17 pm
If it's an adafruit library, you'll likely have to read through the source code yourself.
https://github.com/adafruit/Adafruit_Ci ... thon_Motor
millercommamatt
by adafruit_support_carter on Mon Feb 11, 2019 1:42 pm
The CircuitPython documentation is hosted on Read The Docs. One way to get there is to click on the doc badge in the library's repo readme:
In the case of the Motor library, that'll lead you here:
https://circuitpython.readthedocs.io/pr ... en/latest/
and then you can look at the documentation for servo:
https://circuitpython.readthedocs.io/pr ... otor-servo
Another way to do a quick check in CircuitPython is to use the dir command, once you've created the servo object:
dir(servo)
by drtomsutherland on Mon Feb 11, 2019 1:53 pm
How do you find other libraries besides the Motor library? Like board, pulseio, time, etc... Is there a listing of all of them?
drtomsutherland
by adafruit_support_carter on Mon Feb 11, 2019 2:18 pm
In general, should be the same for other libraries. Should be able to follow that link to get to Read The Docs.
However, there's a special set of libraries that are "built in", which are called the core modules, and "board" is one of those. Since those are considered to be part of CircuitPython itself, look here:
https://circuitpython.readthedocs.io/en ... index.html
We don't have a single list of all the other libraries. It's constantly evolving. You can get a list of sort by looking in the library bundle repo here:
https://github.com/adafruit/Adafruit_Ci ... es/drivers
Each one of those is a link to an actual library repo.
