1st Time Trinket User - IDE Not Working Right? - Board Manag
by Benallen1024 on Sun Mar 17, 2019 11:15 am
Howdy,
1st time poster and adafruit trinket user. I am running into a bit of an issue finding my board for the Trinket in the boards or board managers. I've tried to download other boards, trinket drivers and nothing seems to be working. Also having a port issue? Not sure what this means since I am totally new. I appreciate the help all.
Downloaded drivers from here : https://learn.adafruit.com/introducing- ... dows-setup
https://imgur.com/a/q6b8dr6
Here is an imgur post of the screen caps of the issues I'm running into if this helps.
Ben
Issue 1
Benallen1024
Re: 1st Time Trinket User - IDE Not Working Right? - Board M
by XRAD on Sun Mar 17, 2019 11:38 am
Which Trinket? 5v, pro, M0....
AVR 3.3/ 5v: did you add the correct adafiles for all the boards to the arduino IDE? I do not see any adafruit trinkets listed.
https://learn.adafruit.com/add-boards-a ... 4/overview
If so you will also have to use the tinyUSB under 'programmer' to load it......
Trinket M0 is easier to use.....
XRAD
by Benallen1024 on Wed Mar 20, 2019 12:14 pm
Yes! This was perfect! Thank you for helping me get the boards uploaded. It worked like a dream. Now I just need to learn how to code for RGBW strips
Benallen1024
by XRAD on Wed Mar 20, 2019 8:09 pm
your welcome. Glad you have progressed. The fun factor (with or without the parallel challenge factor) is about to get exponentially better!
https://learn.adafruit.com/adafruit-neo ... ibrary-use
'googlefruit' is your best friend......
XRAD
